Question about Hitachi 50V500 50 in. HD-Ready LCD Television
My lamp light is blinking after changing the lamp out
The television went out and the lamp light came on. Got a new lamp in and changed it out but now the lamp light is blinking. I have checked the cover to be sure it is on securely several times but it doesn't fix the problem. What else could the problem be.
  • 3 more comments
  • Anonymous Dec 07, 2007
    NEW LAMP IS IN BUT LAMP LIGHT KEEPS BLINKING RED STATING NEEDS NEW LAMP
  • miketheplmbr Dec 12, 2007
    I,m on my 4th lamp in 3 years . Changed the lamp 2 months ago,and it has burned out again. Also had the light engine replced after 2 years .Poor design ? Need help...
  • edavenpo Dec 14, 2007
    I have the exact same problem and am stuck with this expensive new lamp I bought, did you ever get it fixed? We are missing lots of great christmas shows and the family is getting upset. Thanks.
  • Anonymous Nov 16, 2008
    My lamp light is blinking after changing the lamp out problem, and notify you when a new solution is offered.
  • tingolden Dec 14, 2008
    I had already ordered a new lamp when the lamp light came on. Old lamp was three years old. The new lamp worked for a day, then the lamp light came back on. When the technician came back out, he adjusted the contacts for the light sensor. It worked until he got into his truck. Then the temp light came. I hit the power switch, and the temp light went out and the lamp light came on. I ran out and got him, he hit the on switch, and the screen went white. He unplugged the TV, turned it on, and it worked for two days. Then it didn't work for a week. Then it worked for two days. Now it's not working again. One more shot at fixing it, then I'm going to get a new TV.
    When I bought this TV 5 yrs ago, I got the extended warranty, which paid for the light engine that went out 18 months after I bought the TV.
    Genius:
  • 1,694 Answers
Bad new lamp??....T.
Posted on Oct 25, 2007
  • 790 Answers
Maybe you have lost contact at the lamp circuit! or check the lamp circuit.
Posted on Oct 02, 2007
SOURCE:
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Samsung 56" DLP tv. was watching and it went off. light on lower front blinks 3 times, when attempt to turn on. Could it be the lamp light?
Does these LED indicator lights that blinks?It is one of the LED light said lamp or bulb?The tv been used alots,and it at lest 2 years.U have not change the tv lamp or bulb to this tv?Change it,life of the lamp it over.
May 03, 2010 | Samsung HLP5067W Television
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
MY SAMSUNG TV MODEL HL-T5075 S DOES'T WORK ,ONLY THE THREE LIGHTS INFRONT PANEL ARE BLINKING
I DONWLOAD THE MANUAL AND READ IN THE PART OF THE FRONT LEAD AND SAY WHEN THE THREE LED ARE BLINKING YOU HAVE TO CHANGE THE LAMP,AFTER I WENT TO THE samsungparts.com AND ORDER MY NEW LAMP THAT I HAVE TO WAIT TWO DAYS.
THANKS FOR YOUR HELP
Nov 24, 2008 | Televison & Video
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
427 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
