Question about RCA P46922 TV
TV turned black while viewing and then started clicking
We've had this tv for about 7 years, so I am sure that it may have been a life issue; but I am hoping that there is a fix since we love it so much. I periodically was having issues with the screen turning black, but if you changed the channel back and forth it would be fine. This didn't happen too much until today, it happened twice and after the second time it went back to the channel, made a click noise and it turned off, I could tell the power was still working to it and all it did was make this annoying clicking sound. So, I unplugged it and plugged it back in and it is still doing it. The circuit breaker did not blow, any advice?
  • bnknboys Oct 03, 2007
    Thanks Terryfic!
    Now, tell me is this something I would be able to fix myself and save some cash? The whole service # is P46933YX1, not that may help you of course.
    If I can put other things back together, like cars and computers, surely I can find this flyback transformer and replace it, right?
    Oh, and thanks for your time!
    New Friend:
**** a ****
Posted on Nov 04, 2012
    Genius:
  • 1,694 Answers
Bad IHVT AKA flyback transformer.Be sure to give complete service # for correct part #. Service # is three characters longer than the model #.
Posted on Oct 02, 2007
SOURCE:
My 60 inch Mitz keeps blowing bulbs
I have to assume you are referring to a projection TV when you say bulbs. With that in mind, the lamps do run hot so you want to make sure the TV has adequate ventilation around the TV grilles first. Next you want to make sure the lamp fan(s) are clean and no dust blocks the fan or cabinet openings the fan draws air from. That takes care of air circulation. The lamp itself has a relatively short life span of 2 to 3 years, I can't remember the hour rating off-hand. I have seen some last a year or just under but that's usually for high viewing times like 12 hours a day more than likely. Beyond that, the lamp ballast (power supply) could be an issue but it's less likely.
If you are changing your own lamps, make sure you don't touch the lamp with your fingers as the oils can from you skin can shorten the life of it just like it does with any quartz bulb, like halogen bulbs.
Jan 23, 2016 | Televison & Video
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
I've had my Hitachi 55" model #55VG825 TV for
As it is 7 years old, replace all the electrolytic capacitors at its main power regulator board. All of them might have value deteriated. If so, power supply wont get proper regulation. If you wish to get more details, check this link.
Apr 22, 2013 | Televison & Video
Gateway MX6956(upgraded to Windows 7 Ultimate) will not connec,t via VGA inputs, to my Panasonic TC-P50G20. Why? Why? Why? It worked for years with XP.I've tried every configuration. I'm guess
Right click on desktop, go to 'graphics options' and then to 'output to'. Go to 'clone displays' and select 'monitor + built-in display'
It helps to have the TV plugged into the VGA port on your notebook before you turn that on.
Jan 29, 2018 | Televison & Video
Tv will not turn on. Start to fire up then after about 1 second it shuts down. Never gets a chance to find a picture.
This issue is a common, but hardly talked about from LG. Your tv is probably 1 or 2 months out of warranty, and now you're hearing a series of clicks. After weeks of fighting with LG to replace my tv, i decided to fix it myself. i'm proud to announce that my 50PK540 is now working. want proof? Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis several 50PK750 models, Some clients have send me their broken power supply board, so I can do the repairs. Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at [email protected] if you have any question.and watch the video:
http://www.youtube.com/watch?v=I9wF0OLyV0k&feature=youtu.be
http://www.youtube.com/watch?v=vHrv5XaDULI&feature=youtu.be
Jun 29, 2011 | LG 50PK750 50 in. Plasma HDTV
I have a life view and my computer is windows 7 and when i install my old life view it doesn't work i think my life view supports win me or 2000
sounds like a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 20, 2011 | LifeView FlyTV MCE TV Tuner/Video...
Blinking red led light when I plug in the tv then it turns right
Phillips purchases the main circuit board from Samsung, and it has a problem with capacitors failing. The failed capacitors can be easily identified as the top will no longer be flat, but will have bulged up.
If you have a local TV repair shop they can help you.
Jul 26, 2009 | Philips 42PF7220A 42 in. Plasma Television
My 6 to 7 yr old television suddenly went dead
There is a board that manages the power going into your tv I would check around with local mom and pop tv reapir shops. The board is not expensive its the labor I am not sure where you live but I am sure there are local techs that work on flat panel tv's. They are pretty affordable these days. Most flat panel tv's are rated for 60,000 hrs as there life span. Hope that helps
Mar 25, 2009 | Panasonic Televison & Video
60" RCA PROJECTION TV
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Dec 29, 2007 | RCA P60921 60" Rear Projection Television
RCA P46922 TV Logo
74 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
