Question about Siemens SpeedStream 4200 (13A4200001) Bridge
Is it possible..
My phone line has not been working at all, tried different phones and everything. Is it possible that pop spilled on the modem could do this? its actually a problem that was fixed this morning by the phone company....the internet was working and only the phone was down, but the tech claimed the dsl modem was bad and thats why the phone didn't work.... is that even possible?
    Sergeant:
    Champion:
  • 317 Answers
Two things:
1) Is your phone bill paid?
2) Have you installed filters on the phone line and data line?
3) as you said, check for anything sticky on the speedstream itself, something might have been spilled, or even water for that matter.
Posted on Dec 10, 2007
SOURCE:
Had a very close lightening strike in my back yard. Everything was connected to a sorge protector. It fried my Cox Cable modem, my telephone and the #2 phone jack on my all-in-one. Bought new phone and...
Yes it is likely the HP All In One is damaged - I suggest you put your money towards a new All In One as a repair most likely would not be a cost effective solution.
Jun 09, 2011 | HP OfficeJet J4580 All-In-One Laser...
Theres no dsl light on the router, its a d link dsl2640b. so i need to know if its broke, the power light is on and the status light but no dsl light and no internet light on router, the pc is showing...
The flashing DSL light means that the modem isn't seeing the DSL signal on the phone line it's connected to. This might be due to modem failure, but it might also indicate a phone line problem. The most common trouble I run across is an unfiltered device connected on the line that interferes with the DSL signal. Other than the modem, all devices (phones, fax machines, security systems, etc.) need to be connected to the line through a filter. Check to be sure something hasn't been connected without a filter. Sometimes a phone gets moved or a new phone is added that gets plugged in to a handy jack without being filtered.
If you can, try connecting another modem to the line. You may be able to borrow one, or find one at a resale shop. I see them quite often for only a couple of dollars, leftover from people changing to FiOS or cable service. This can help determine if the modem is responsible.
One final possibility: your DSL service has been cut off. I've had two cases where loss of DSL was a phone company issue that they needed to fix at their office. (One following some wiring work done in apartment building, the other when service was mistakenly disconnected from the wrong customer.)
This kind of trouble can be a headache to solve, but it can be solved. Good luck and thanks for using Fixya!
May 21, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
What to do if dsl light is blinking
This likely means that your DSL modem is not trained up with the DSLAM. - Geek talk for your modem is not connected to the phone company's equipment properly.
1.) Remove power from the modem
2.) Remove all devices (including the DSL modem) from all phone jacks in the house.
3.) Add the DSL line back to the wall jack, taking care to plug the wall jack into the correct jack on the DSL line. (Do not use a DSL filter on your modem!)
4.) Power up the modem/
Still not working? Continue...
5.) Try a different phone jack
6.) Try a new phone cable between the wall jack and modem
7.) Call the phone company for further assistance.
Dec 18, 2010 | Siemens SpeedStream 4200 (13A4200001)...
Phone isn't working. Message flashing says "Waiting for synch"
This happens on the older software levels of the Mitel phone systems when the phone type programmed does not match the phone type connected. Example: if the phone system programming has a 4015 phone type for that port and you connect a 4025 phone you will get this result. Another cause could be the port you are connected to is analog(used for analog devices such as fax, credit card, modem, or standard single line phone) instead of digital; you would get this result even on the latest software levels.
Assuming that this is the same phone that has been at this location and was working previously, try a different working 4025 phone at this location. If the different phone works, then the problem is in the phone and needs to be sent for repair. If the different phone doesn't work, change the line cord to eliminate possible bad line cord. If the phone still does not work, the problem could be in the outlet, building wiring or in the telephone system. At this point you likely need to call a service technician to track where the problem is.
Dec 10, 2010 | Mitel Superset 4025 Corded Phone...
I cannot receive faxes using my fax console in WinXP. There is no dial tone. When I query the modem, the log reveals this command in the frame: AT#CLS=? COMMAND NOT SUPPORTED. I used to be able to...
Hi:
I have'nt used computer modems to fax in a long time, but will try to help, If you can edit the command line enter ATDT this command means Attention Dial Tone. Enter this command to see if you hear a Dial tone. I also suggest you try taking out the modem to reset it. let windows load without the modem in the computer then shut down windows compeletly and reinstall the modem so windows can reinstall the drivers for the hardware, if you have upgraded windows to a different version since you last faxed, then it would be wise to look for updated drivers.
May 14, 2010 | Computers & Internet
Is it possible to have 2 modems in one house
Yes. If you have 2 telephone-lines, then each modem can simultaneously be used.
If you have just 1 telephone line, and multiple wall-outlet jacks, you'll have to "coordinate" the dial-up usage -- when the first computer is connected via the modem, the second computer's modem will get a "busy" signal.
Each cable-outlet in your house can have a cable-modem -- they can be used simultaneously.
However, you can only have one DSL/ADSL adapter per telephone-line.
Nov 06, 2009 | Computers & Internet
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
I have s dell studio 15 laptop. i got a dell conexant rd02-d400 modem so i could use dial up with it. now i get errors that say it can't connect, but that everything os ok.. error 692 and 618 (i think)...
hello,
Connect your modem to the phone line and test the modem.
Control Panel-->>Phones and Modems. Click icon. Tab Modem. Highlight your modem, and Click Properties--->>Diagnostics. Verify that everything is OK.
Then Start --->>All Programs -->>Accessories-->> Comunications ---Hyperterminal.
Enter a name for a bogus connection, Click OK
Enter your phone number and dial it. If Phone/Modem connection is OK, you shoul hear the busy signal.
Alternative:Run the Dell diagnostics.
If Modem connection is correct you must then create a dialup connection.
Hope it helps.
Sep 12, 2009 | Dell Computers & Internet
When I tried to go online my Compaq Presario SR110nx gave error 680
Error 680--- No dial tone
A) Test modem by dialling a number through HyperTerminal or phone dialler. This will test the Modem without using Dialup Networking.
B) Make sure you are using the correct and/or original cable. Some modems used specific wiring which is not compatible with standard modem cables.
C) Check that you phone line is working with a normal phone.
D) Make sure the phone line you are trying to dial on is not a non-standard line, this can cause problems also.
E) If all the above are OK then get a new modem or test in a different location.
Sep 01, 2008 | HP Computers & Internet
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
