Question about Palm Tungsten E Handheld
Tungsten E I havent used my Tungsten in a while and now I'm trying to use it but it will only turn in with the charger connected, all the data is erased as soon as i disconnect the charger. I keep pushing the power button but nothing happens? its frustrating
  • Anonymous Feb 06, 2008
    I bought the Tungsten E and left in the case for a long time, more than a year. Now that I want to use it it won't work, I plugged it for several hours for the first time and it turned off when it is not plugged. It only turns on with the charger.
    It's brand new and I can't use it!!!
I wanna a cd software for my tungsten e.
Posted on Sep 16, 2008
Logitial download for tungsten e (2003)
Posted on Dec 29, 2007
  • 4 Answers
Hi : This means your battery must be as dead can be. Therefore it seems to be getting straight power only when you plug in the charger. Or your on/off button is dead. Are you able to turn it off/on when you have charge plugged. If so then I suggest getting a new battery for the E2 Palm and you should be back up and running. If this is not the case then it is your on/off button in which it could be just the contact or the switch itself. I can suggest someone in US if you like, else I can handle it but I am in AUS.
Posted on Oct 06, 2007
My palm tungsten e2 does not power on at all? what is the solution. i tried soft reset. it did not work out.
It could be the battery. may be the charger is stuck ,did you Connect the E2 to the charger then soft reset ?this should reset the charging circuit on the Palm.after that Let it connected to the power adapter for a good 2 hours. After that, disconnect the Palm and see if it will turn on. If not, then you need to get a replacement battery for your Palm.hpe this helps.pls do let me know thanks
Jan 12, 2010 | Palm Tungsten E2 Handheld
It will not turn on. It is 3 yrs old.
If it is not turning on at all then more then likely the battery is dead. Try plugging it into the charger and leaving it for over night. Then try turning it on. If that doesn't work you may need a new battery. I would not recommend doing this yourself s it involves some soldering. I had a friend of mine change my battery and it didn't quite work right after that. I am also including a link for the free chat feature that palm has. I have used it several times and have always had very good results. Best wishes.
At the bottom of this page it says Palm Chat. Click on the chat now and follow the online prompts.
Nov 19, 2009 | Palm Tungsten E Handheld
Ipod was working fine. Havent charged in 1.5 days now it will not even turn on? What should I do?
dear sir,
when u charging it what u use, connect with charger or PC?
1) first check your data or charging cable.
2) check your charger.
3) check your ipod socket wher connecting charger's jack or data cable. bcoz sometimes it damaged for mis handelling.
if both r ok then, u can check your battery but if u don't have previous idea to do the work, plz contact with qualified technical person.
hope you get the answer.
Oct 21, 2009 | Apple iPod nano
Tungsten e2 won't power up
Please follow the steps to isolate the problem:
1. Make sure that the charger is working.
2. Try using different charger just to make sure.
3. Try using different battery.
If the phone works using different battery, you need to replace your old battery, but if not, this phone needs repair.
Apr 17, 2009 | Palm Tungsten E2 Handheld
Will not turn on
It's possible that the battery can no longer hold a charge anymore.
Check with Palm to see if there is a replacement available.
It should work if you have a car charger on it while using it.
Mar 31, 2009 | Palm Tungsten E2 Handheld
I haven't used my palm in a while
If you don't remember the Palm password, you'll have to do a hard reset, which will erase all of the data.
Then, please download the latest Palm Desktop version from and install it on your system.
After both of these steps, you should be able to sync.
Mar 19, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Lost calendar data tungsten E
palm tungsten E software missing pleas i neet
Mar 14, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Tungsten E2
Have you tried pushing the reset button on back to see if it comes on?
Nov 26, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E Handheld Logo
262 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
