SOURCE: dell computer won't work with docking station
reinstall the chipset and ricoh drivers from support.dell.com. also reinstall the notebook system software under utilities.
SOURCE: Dell D610: Does not charge w/ any a-c adapter/battery pack.
This seems to be a shot in the charging circuit of the motherboard. If in warranty call Dell hardware supoprt and they will do the needful in warranty. If the warranty is out try a local technician and maybe they can repair the board.
SOURCE: My Dell Latitude 610 won't start. I have tried
Will your laptop start if the battery is removed and the power supply is plugged into the laptop? This would indicate a battery problem.
Make sure you are using the correct power supply for the DELL D610.
It should be PA-12 family. Model AA22850.Output 19.5V.
SOURCE: how to disable touch pad for dell precision m4500
Please go to Control Panel->System->HW->Device Manager. Click on the Mouse and Other Pointing Devices. Select the Touch Pad and from Action in menu select properties. In Advanced option her you can disable the touch pad.
SOURCE: how do you view the
Please follow these steps,there are different way on going to BIOS depending on the brand of the laptop.
Turn on your computer
Hold down F2, this will take you into BIOS. On some computers it might be the DEL key, or F1.
Change the settings in BIOS to what you desire. You will see parameters for various devices, if your BIOS allows it, you can even overclock the CPU.
Look at the BIOS menu. You will be able to see the make, model, and capacity of your hard drive, processor speed, time and date, among many other settings.
5
Click "exit without saving changes" if you make a mistake, and nothing will be changed.
Hope this will help...Your response is very much appreciated...
