Question about Riso RZ310 Duplicator
Lexmark 4039 10r
Copies come out with streaks, believe drum is dirty. Do not have manual. thanks kinwod
    Problem Solver:
  • 5 Answers
Dear sir
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
[email protected]
Posted on Sep 02, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Riso Master
  • 1,362 Answers
I'm pretty sure this is a printer not a copier.
Take out the cartridge and turn it upside down, you will see a (Usually) green cylinder, does it have a ring of toner, or does it appear to have been scrathed ?
Take the copy and put it next to the drum, does the lines match? Then replace cartridge.
If not open back and take out fuser ( two screws for cover and two screws for fuser, are the rollers o.k? replace fuser.
Posted on Oct 26, 2007
SOURCE:
Copies come out with dark streaks
Looks like a dirty, scratched or contaminated drum. Try wiping the drum with a very soft cloth, the streaks should go away but may re-appear. If there are visible marks on the drum that cannot be wiped of with the cloth, the drum will have to be replaced. DO NOT TRY USING ANY SOLVENTS TO CLEAN THE DRUM.
Jan 25, 2011 | Canon imageCLASS D660 All-In-One Laser...
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
Jul 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Looking for a service/repair manual
At minimum, the drum and cleaning blade need replacing - possibly developer as well. I'm sure the optics are dirty, as well as the charge and transfer corona.
Apr 29, 2009 | Office Equipment & Supplies
Intermitantly streaking copies
Sounds like the wiper blade in one of your cartridges has failed. Try swapping cartridges and see if this helps. The problem could be with only one of the cartridges, so try changing one at a time to find which one is causing the problem
Jan 23, 2009 | Lexmark C750 Laser Printer
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Streaks on copied paper
You have a failed drum cleaning blade that lives in the drum cartridge. The blade is replaceable as a seperate item.
Jan 31, 2008 | Xerox 5305 Copier
Streaks on paper
Nisha... If you haven't done so already, you need to run a few copies off the glass as opposed to through the feeder to determine "where" your problem is. Do the copies of your originals placed on the glass have the same line/streak defects as the ones made run through the feeder? IF NOT, then you probably have some sort of dirt or contamination on the FAR RIGHT side of the glass (ink, white-out, dirt, etc), and the machine is reading that as part of the image and printing it as a line. When running copies through the feeder, the scanner moves to the far right and parks there. Then the feeder moves the original over the scanner on the right side of the glass (the scanner stays still). So if you find the lines evident when using the feeder, but not there when copying off the glass, you need to clean the glass on the far right. IF YES (lines/streaks through the feeder AND off the glass), then your problem is most likely internal of the machine (bad drum in the L50 cartridge, dirty optical scanner, worn fuser rollers, etc) and I hate to say it, but will probably require a service call to rectify it. Sometimes you can actually take the L50 cartridge out immediately after running a few copies, and while holding it up, manually open the spring-loaded drum shutter on the under-side of the cartridge to expose the drum and visually inspect it to see if the line defects on your copies are evident on the drum itself. If so, you will most likely need to simply replace your cartridge and hopefully save a service call. If you can't really tell if the streaks are on the drum itself, then you're back to probably needing a service call. NOTE: DO NOT TOUCH, WIPE, CLEAN, OR OTHERWISE CONTAMINATE THE DRUM WHILE YOU ARE DOING THIS, and do not leave the unit exposed to light for longer than a minute or so, because if the problem isn't evident/obvious with the drum cartridge, you don't want to risk damaging/contaminating it and thereby causing one. Please let me know if any of this was helpful. Thanks.
Oct 03, 2007 | Office Equipment & Supplies
517 people viewed this question
Top Riso Office Equipment & Supplies Experts
Runepic
Runepic
Level 1 Expert
Ekse
Marvin
Marvin
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
