Need wiring schematics for a John Deere L110 with a Kohler comman 17.5hp. Serial No 3231109833
Howdy. Email me. Have a PDF.
< [email protected] >
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
