Question about Oreck XLS700A Upright Vacuum
I cant get the roller back in place
Please help i have a kirby that i cant get the roller back on after taking off and putting on a new belt! it is driving me nuts!
  • 2 more comments
  • pigpeddler Nov 11, 2007
    I took it apart to clean the belt. Now I can't figure out how the white plastic dog and spring fits inside to keep the sweeper head in certain positions.
  • bev4ever Nov 15, 2007
    i cant open my vaccuum i took it apart and cleanened it but now i cant open it to put the roller brush back
  • Anonymous Aug 12, 2008
    reset button won't reset
  • nal1208 Oct 10, 2008
    how to replace the belt
  • 281 Answers
On the ends of the roller turn the ends and you will see some teeth ,the teeth are supposed to be aiming down.if its because of the belt,slip the belt over the roller then put the belt on the motor shaft first and pull the roller towards the front and slip it in the slots or you can put the roller with the belt on it and put the roller in its slots,then stretch the belt towards the moter shaft and if you can get part of the belt on then just turn the roller by hand towards the motor and the belt will walk its way onto the rest of the shaft
Posted on May 03, 2009
  • 357 Answers
This guide should help.....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Please rate it when you are done reading it if it was helpful. :0)
Marci
Posted on Oct 16, 2007
Is the dial on the head supposed to be turned to belt on or belt off when vacuuming
HI There,
This is a confusing system that Kirby has designed here. This is a source of many questions that we field on a daily basis. There is an exact procedure that needs to be followed when removing the head of the machine that has the roller brush and belt.
You need to have the dial set to Belt On when vacuuming, but when you first put the head back on after using the attachment hose, shampoo attachment, or replacing the belt, you need to first put the head onto the front of the Kirby with the Belt Off setting, then after it's connected to the front, turn the dial back to belt on.
Here's a helpful video that we've recorded showing the exact proper procedure you need to follow on your Kirby. This will also show you how to do basic maintenance on your Kirby's roller brush.
Hopefully this was helpful for you. If you have any follow up questions, or need further help on anything for your Kirby, please feel free to use the comment field here on Fixya, and I'll be more then happy to answer any of your questions. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
May 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Roller brush not spinning?
THIS GEEN LIGHT MEANS THAT THE BELT HAS COME OFF. THE REPLACEMENT IS AS FOLLOWS: FLIP THE BRUSH (RUG RENOVATOR) OVER AND REMOVE THE SCREWS ON THE SILVER GUARD THAT KEEPS THE ROLLER IN PLACE. SLIDE THE ROLLER UP OUT OF THE SLOT, TAKING NOTE ON THE HALF MOON SHAPED SIDE. REMOVE THE OLD BELT(OR WHAT'S LEFT OF IT). PLACE THE BELT AROUND THE MOTOR SHAFT FIRST. THEN AROUND THE WOODEN BARE SPOT ON THE ROLLER. PUT THE ROUND(CIRCULAR) SIDE OF THE ROLLER IN FIRST, THEN CAREFULLY STRETCH THE ROLLER WHILE HOLDING IN THE ROUND SIDE IN ONE SIDE AND ROTATE THE ROLLER UNTILL THE HALF MOON LINES UP TO THE SLOT. PUSH IT DOWN INTO THE SLOT AND PUT THE ROLLER COVER BACK IN PLACE AND RE-INSTALL THE SCREWS. AND THERE YOU HAVE IT. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANK YOU FOR THE HONEST RATING AND FOR USING FIX-YA.
May 04, 2009 | Kirby Heritage II Vacuum
How do you change the belt on a kirby sentia vacuum cleaner?
ok Imussati here is how you change the belt take the roller brush out and put the belt in the center of the roller brush place the roller brush back in nowtake the name plate and twist it until the hook graps the belt it may seem like it is to tight but keep turning it once you get the belt twisted to the highest point put the nozzle back on the vacuum and lock it down then turn the face plate back the way it was and it should allow the belt to slip around the driveshaft and you are ready to roll. hope this helps
Jan 24, 2009 | Vacuums
Is there a drive belt on the heritage 84
Yes it has a belt. Could be the belt or a worn out brush roller, or you don't have the height adjustment set right. But I would check the belt first. It is the cheapest part and if you haven't changed it lately it probably needs it anyhow.
If you haven't changed the belt before it's a little tricky.
Turn the knob on the front to the belt off position, and unlatch the top of the nozzle to remove it. Pull the nozzle off and turn the knob to the belt on position. Take off the bottom plate and take out the old brush roller and belt. Pay special attention to how the roller comes out. You don't want to get it in backward.
Put the new belt on the roller and center it. Put the roller back into the nozzle and put the bottom plate back on. Turn the knob to the belt off position you should be able to see through the hole in the back, the hook pick up the belt and stretch in up.
Put the nozzle back on the unit, latch the top, and turn the knob to the belt on position. Simple Right? LOL
It has to be one of the most complicated machines to change a belt on .
P.S. they usually give you extra belt when you buy it, and the new style knurled belts work fine as well.
Good Luck-Don't be afraid to ask another question if that doesn't solve your problem.
Dec 01, 2008 | Kirby Heritage II Vacuum
How do you install the belt on the kirby vacuum?
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Nov 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Replace the roller on my kirby vacumm generation 3
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=814340
Generic problem for all Vacuums
Posted by tlourene on Jul 21, 2008
Replace the roller on my Kirby Vacuum Generation 3
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to replace the brushroll on the Kirby G3 you need to dial off the belt and then release the lever to remove the bell housing, then there are 2 levers that you need to open then you can get @ the brushroll --- take out the brushroll and replace the brushroll and a new belt – make sure you change the belt every 4 to 6 months for the best cleaning. Make sure when you put the new belt in the housing that the screw heads are facing down – then you can replace the bottom plate, dial the belt on to the belt pulley and replace the bell housing. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 21, 2008 | Vacuums
Hi....Need Help please....
Put the belt on the brush roll, place it in the nozzle, make sure the belt is in the center, turn the big knob on the front until it locks, then install the nozzle on the vac., turn the knob in the other direction, and it will be put on the pulley.
May 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
My belt broke on my kirby upright, I took the roller off and put the new belt on, but I cant get the hook to hook on the belt.
On the front of the nozzle is a big knob that you turn to load the belt. Take the nozzle of of the vac, turn the knob to catch the belt, keep turning it until it stops. You will know if the it caught the belt, it will be hard to turn. Put the nozzle back on, lock, then turn the knob in the other direction releasing the belt unto the pulley.
May 01, 2008 | Vacuums
Replacing brush roller on my KIrby g6 limited edition
You need a new belt. When the green light goes out, that means your brushroll has stopped spinning. Here's how to change it....
Even if you just replaced the belt, this guide will help you make sure that you got the brushroll back in the right way.
Hope it helps....
Marci
Dec 08, 2007 | Kirby G6 Bagged Upright Vacuum
Oreck XLS700A Upright Vacuum Logo
286 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
