Question about Dell UltraScan P1110 21" CRT Monitor
Dell P1110 This thing works great...but...whenever I shut it down, and then try to turn it on again later, I have nothing on the screen (color bars) and the LED continues to blink green, until about 10 minutes later, it magically come back on...I?ve tried to find some info like when I hade the brightness problem, but I have not had any luck. Pleas help!
    New Friend:
    Problem Solver:
  • 14 Answers
Using the buttons on your monitor, see if there is a "burn in mode" or "self test mode", and turn it off via the monitors other buttons. (not the power switch)
Posted on Jan 06, 2013
  • 59 Answers
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Posted on Oct 03, 2007
SOURCE:
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
en.community.dell.com/support-forums/laptop/f/3518/t/19496556
Dell
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from en.community.dell.com
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
Dell optiplex 170l screen problems on shut down
Disconnect the monitor cable from the computer and power on the monitor. It has a built-in diagnostic program. If you see color bars floating around the screen then you monitor is O.K.
Jul 24, 2012 | Dell Computers & Internet
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
WHEN I TURN IT ON ALL THE GREEN LIGHTS LIGHT UP ,THEN ABOUT 5 SECONDS LATER IT TURNS OFF,NOTHING EVER COMES UP ON THE SCREEN
I guess this is not an intermittent issue though right? Kindly do these process/procedure if things able to work.
1. Remove the Optical Drive.
2. Remove the Hard Drive.
3. Remove all memories (RAM).
After removing those devices try to turn on the laptop eventhough it produces beeping noises and stay in the BIOS screen. Have to observe if it restarts again or shuts down on its own. If the scenario appears that it is still shuts down after 5 seconds then, motherboard is not working properly. Actually there would be more troubleshooting steps for this to isolate the issue. If you can able to follow some of the steps then my piece of advice is to call Dell technical support for some assistance by removing some of FRU devices. Things are more likely critical. If you're unable to do the thing then have then replace the laptop in this regard if it is still under warranty. That's one of a good thing. Hope things will help you to determine. Thank you.
Oct 09, 2009 | Dell Latitude D600 Notebook
Flip Ultra - freezes at initial Flip screen - will not shut off
I found a fix that worked for mine.
It was doing the same thing, freezing at the "Flip" screen and would not turn off. I did the remove the batteries deal. It worked once but issue reoccured 2 months later and the battery fix didn't fix it.
What did fix it was...
With the camera off, hold down the Right Arrow button and the trash can button at the same time and turn the camera on.
A few seconds later, I was at the start recording screen!!
Good Luck!
Jul 21, 2009 | Pure Digital Flip Video Ultra Camcorder
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
Kinda frozen just weird
I got the same problem with my old sansa. All i did is return the product with the facture to the store and they gave me a new one.
Apr 26, 2008 | SanDisk Sansa e260 MP3 Player
Ultrascan P1110 to Bright....
hi sounds like you have weak picture tubes do not open the screen ***DANGER OF ELECTROCUTION AND DEATH*** try taking to some1 who knows how 2 fix it good luck
Feb 22, 2006 | Dell UltraScan P1110 21" CRT Monitor
Open Questions:
See all Dell UltraScan P1110 21" CRT Monitor Questions
Dell UltraScan P1110 21" CRT Monitor Logo
293 people viewed this question
Ekse
Clive
Clive
