Question about DeLonghi DE500 Dehumidifier
DE 500P My unit occaisonally leaks water from a clear tube behind the water tank that comes through a metal shield. i hve no idea what this tube services or where it has come unconnected or unplugged?
  • Paniculata Apr 20, 2008
    Same problem but it's not just occasionally. I assumed this was an air intake or overflow tube, but cannot find any technical manual on line to verify
This tube is likely related to the water pump out feature that these have. They have a pinch clamp on connections, perhaps your clamp is loose or misaligned.
Posted on Jun 20, 2008
6ya staff
SOURCE:
What diameter tubing is used with the Delonghi DE 500P pump
George, regular garden hose is what is generally used for continual drainage. Just don't exceed the maximum length of hose, that is listed in your Owners Manual.And, despite what they say about being able to pump water up thru abasement window, it really doesn't work that well. Unless the unit is right below the window,
Hope this helps you and thanks for choosing FixYa.
Sep 04, 2011 | DeLonghi DE500P Dehumidifier
I just came home to my DeLonghi (DEN500P) leaking on my basement floor. The bucket will not fit flush because the clear drainage tube has detached. I use the manual emptying method. I have the manual,...
there should be a pump somewhere near the pan, the pickup for the pump must go into the drain pan somewhere if you can find the pump, the nipple the hose attches to is close by please rate
Aug 01, 2011 | DeLonghi DE500P Dehumidifier
My DeLonghi dehumidifier is collecting water but not into the bucket. Rather it leaks it all on the floor. I have cleaned the filter and even the coils to no avail. Please help.
The drain tube that drains the water into the bucket is clogged and needs to be cleared.
To do this, you will need at least an 18" long plastic Zip Tie or something similar. (But, NO wire coat hangers) that will fit into the drain tube or hole. Carefully work the Zip Tie into the hole or tube and gently push it forward. You will reach a bend in the tubing, but you will have to gingerly work past this bend. Once the Zip Tie bottoms out or you run out of Zip Tie. slowly pull it back out while rotating it. This will help breakup the clog. Once you start reaching the end of the inserted Zip Tie, be prepared for some water to follow.
The above procedure should solve the problem. Please let me know. Thanks.
May 25, 2011 | DeLonghi DE500P Dehumidifier
I have a DE 500p it runs but does not collect water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 24, 2009 | DeLonghi DE500P Dehumidifier Dehumidifier
Internal pum hose connection?
I just fixed the same problem on my DE-500P. The pump filter was blocked and there was a layer of scummy lint-like stuff in the bottom of the pump reservoir (not the main - or overflow tank) also blocking flow down through the filter to the pump. Repair steps are as follows:
1. Remove the overflow water tank and the two side covers (five screws in each). Note that as you go through the removal of all the covers and other procedures, there are two lengths of screws; don't switch them. If you lose track, the rule of thumb is use the short screws for going through a single layer of plastic into metal.
2. Remove the rear cover (take out the screws along the bottom and on the sides). It will still be attached to the front top cover at the top with tab fasteners. Gently pull out the bottom of the cover while depressing the top of it on both sides with your thumbs (about an inch and a half inside the trim ridges) to clear the tabs. Ease the top part of the cover back and remove it (it will have to tilt to one side, don't forget this when putting it back on).
3. Remove the top cover, not forgetting the two screws on top by where the back cover attached (go gently, there's a wiring harness) and turn it to the side. There was enough slack to leave the wires connected; just be careful to not damage them.
4. The filter looks like a small transparent in-line gas filter. Remove the pump filter, leaving the short tube attached to the top of it. I quickly atttached a length of tubing to drain the reservoir into a bucket. I couldn't find a replacement filter, so I filed a slot in the side of the bottom half of it to remove the gunk using the wire from a twist tie (the upper half had some tabs inside that would have been in the way). Afterwards, I wrapped it tightly with stretchy electrical tape and put a wire tie over the tape at the slot to keep the tape from being able to creep loose over time. Don't use a fuel filter, the paper element is too fine (you need a screen) and the paper will fall apart in water.
4. Remove the float and bracket from the pump reservoir. The reservoir screws are not all apparent; there's also a screw way over on the left and one coming in from the right. I used a 12 inch #2 phillips screwdriver with a magnetized tip for most of this. Remove the pump reservoir and clean out the scummy stuff in the bottom and where the tubes attach. When removing the reservoir, you'll have to detach the vent line that goes through the bulkhead to where the big tank was and pull the tab above it down slightly while easing the tank out.
5. Clean out any dirty tubes, paying particular attention to the coupling for the drain hose and the long drain hose itself.
6. Put the reservoir back in and hook up all the tubes and filter. It does make a difference in which direction the filter goes back in. You want the water from the reservoir to go through the filter from the outside of the little screen; that leaves the maximum room for crud build-up before it plugs up the screen again.
7. Depending on your confidence level, at this point you may want to plug in the dehumidfier, put the overflow tank in, turn it on, turn on the pump, and fill the pump reservoir to check for functioning and leaks. If you do this, just remember that the circuits are hot and not all are insulated.
8. If all is OK, unplug the dehumidifier and put the covers back on. Total time was about an hour.
Jun 28, 2008 | DeLonghi DE500 Dehumidifier
Pump failure
Jun 26, 2008 | DeLonghi DE500 Dehumidifier
Leak
Mine did this last year. I took the housing off of the left side and found a clear plastic tube had popped off the fitting, I put it back on and it worked fine. The tube was toward the lower front of the unit.
Jun 01, 2008 | DeLonghi DE400 Dehumidifier
The pump doesnt work
I just fixed the same problem on my DE-500P. The pump filter was blocked and there was a layer of scummy lint-like stuff in the bottom of the pump reservoir (not the main - or overflow tank) also blocking flow down through the filter to the pump. The line you tried to plug is probably the vent line for the pump reservoir. It attaches to a fitting on the removable tank side of the bulkhead. Unstop the vent. Repair steps are as follows:
4. The filter looks like a small transparent in-line gas filter. Remove the pump filter, leaving the short tube attached to the top of it. I quickly atttached a length of tubing to drain the reservoir into a bucket. I couldn't find a replacement filter, so I filed a slot in the side of the bottom half of it to remove the gunk using the wire from a twist tie (the upper half had some tabs inside that would have been in the way). Afterwards, I wrapped it tightly with stretchy electrical tape and put a cable tie over the tape at the slot to keep the tape from being able to creep loose over time. Don't use a fuel filter, the paper element is too fine (you need a screen) and the paper will fall apart in water.
6. Put the reservoir back in and hook up all the tubes and filter. It does make a difference in which direction the filter goes back in. You want the water from the reservoir to go through the filter from the outside of the little screen; that leaves the maximum room for crud build-up before it plugs up the screen again. Newer ones have a flow direction arrow; point it away from the reservoir.
Jun 01, 2008 | DeLonghi DE500 Dehumidifier
DE 500P - Fan will not shut off
If you have the fan icon selected, it is supposed to run continuously. If you use the mode button (not the fan button) to change to relative humidity (the water drop icon), the fan should only run with the dehumidifier.
Feb 19, 2008 | DeLonghi DE500 Dehumidifier
DeLonghi DE500 Dehumidifier Logo
206 people viewed this question
Top DeLonghi Dehumidifiers Experts
nm156
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
