Dryers
Problem for Dryers
Generic problem for all Dryers
Gas only comes on for a couple of cycles
By TimHuckins on Oct 02, 2007
I took the panel off the front and cleaned about a 1/2 inch of lint off of the inside. yikes! There was actually a layer that looked like it had been smoldering.
I can see the igniter working and for the first two or three cycles the gas comes on as well. Then the gas stops coming on and the igniter cycles on and off at about 10 seconds per minute. No gas and no clicking noise that it usually makes when the gas comes on.
I also took the lint chase apart and cleaned it all out.
I also took the dryness sensor(?) out and wiped it down and made sure all of the connections were solid.
I also made sure the vent pipe going to the outside was clear.
I'm guessing it might be the sensor and it is not telling the gas servo to turn on the gas because the clothes are still wet.
It is converted to LP.
Comments:
Nov 13, 2007
- I replaced the coil packs and it has been working perfectly ever since.
Same Problem
Apr 11, 2009
-   My dryer is natural gas, I have replaced the igniter thinking it was defective but that didn't work. It will light once or twice then will not light again.-   Guest
Oct 08, 2008
-   I have a new ge gas dryer dpsr610ggwt. The gas come on for 35 seconds and then goes off for apprpx. 50 seconds does this all during the drying cycle. Is this normal?. It does dry the clothes, but I'm worried about it cycling on and off so often.
Thanks
Joe-   joev2233
Best Solution
posted on Oct 02, 2007
Very Helpful)
the dr
Rank: Guru
Rating: 90%, 756 votes
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperatly from any appliance parts retailer or www3.sears.com Of course first thing to verify is gas supply.
Dont forget to rate my solution as solved if I accurately answered your question...Thanks!!
Was this helpful?
Yes
No
Popular Solutions for Dryers
Questions and Unsolved Problems for Dryers
Answer
dryer will not heat and heating element is good.
Answer
how about a 100% dryer and tell me about the advs and disadvs
Answer
tc650 the start button does works the machine but only if it is held depressed.
Answer
I push the button in to turn the Dryer ( Asko 7005) on and it does not continue to run. Only if you... (More)
Answer
performer dryer. no power when dial is pressed
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dryers:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14860
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
