Question about Kogi L9CH 19" Flat Panel LCD Monitor
Problems After Power Outage
We recently had a power outage. After the power came back on I turned on my computer to find that my monitors colors were entirely off, i changed them back best I could then used the "Autotune" feature. This caused the color of the monitor to have a red tint, and moved the display over to the right side of the screen. Manually trying to move the display back does not work (it says its moved over as far as possible) I've plugged the monitor into other graphics cards to double check, but same result on all my computers. Any ideas why this could be happening?
    Problem Solver:
  • 13 Answers
Sounds like the power outage damaged the video interface could be damaged. You might have had a spike that effected the red input of the monitor. You can try to order a video interface, or like I suggest to others, look for the same monitor but broken on ebay and swap out the interface board. Chances are this will fix your problem. Good luck
Posted on Oct 03, 2007
SOURCE:
What do I do after power outage and monitor will not work?
If the device was plugged in when the outage started and / or when power was restored - it may have suffered a power outage related voltage "spike" (or instantaneous rise in voltage greater than it is designed to handle).
Unplug it for 5 - 10 minutes and reconnect. If it fails to function you may need repairs or replacement. Try a different monitor on the computer before condemning it - it may be a problem with the computer's video card instead.
Mar 11, 2015 | Computers & Internet
Tip
Wii won't turn on after a power outage.
Hey, recently had a power outage and now your Wii won't turn on?
Well unless your Wii is completely fried from the storm then this should work (It has for me every time I have had an outage).
After you find out it's not getting power then just unplug the power cable from the wall and from the Wii. Normally I unplug it for about 12-24 hours then you go plug it back into the wall, plug it back into the Wii, look at the power button and if it is red/orange then it has been fixed and you should never have a problem with it again unless you keep it plugged in during a thunderstorm/power outage!
This has happened to me about 8 times and this method worked every single time!
on Jan 26, 2010 | Video Game Consoles & Games
After power outage sound bar will not turn back on
Power supply problems may have occurred as a result of the power outage .... check power supply with a power meter .... see if its outputting ... then check connection to the computer to make sure output is working
Jan 22, 2014 | Computers & Internet
Hi, this morning we experienced power outage in our location, after 5 hours later power came back, but not our main server IBM System x32002. I checked the monitor and there is power. I check the green...
Depending on what caused the power outage, you may need to replace the power supply in the server. When outage happen and the power is restore. a power surge can destroy power supplies, especially if not connected to an UPS unit.
Good Luck
C2Solutions
Feb 17, 2011 | IBM System x3200 M2 Server
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
I have a Magnavox TV/DVD and i recently had a power outage. The power came back on and turned on the TV and the color of the TV screen is a purple or green tint. There is only a tiny circle about 1 inch in...
Remove the the plug from the wall socket(power) plug it back after five minutes. If the power outage was caused by lightning, then it is most likely static on the screen.
Regards
Phillip
Sep 12, 2009 | Televison & Video
Computer wont turn back on after power outage
Try unplugging the cord from the back of the computer for about 5 minutes and then try it again
Apr 14, 2009 | Compaq Computers & Internet
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Envision Monitor doesn't turn on.
monitor has sustained damage from the power fluctuation's from the outage I would report it to your power company they are obligated to replace any damaged equipment that may be damaged because of their failure to provide non outage service and then go take the monitor to a repair center they can determine if the boards internally were hit with a power spike and damaged, meanwhile while you send the report to the power company you can either buy a new one and then submit the price for refund from the power company
May 01, 2008 | Gateway FPD2275W LCD Monitor
No Green
Check the crt board and follow the green signal path, could have a shorted transistor or a resistor out of tolerance on that line, check all the components on that line
Nov 01, 2006 | LaCie Electron 19" CRT Monitor
Kogi L9CH 19" Flat Panel LCD Monitor Logo
111 people viewed this question
Top Kogi Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
