Question about RCA HD52W56 52" Rear Projection HDTV
Convergence my convergence will not stay on just suddenly started doing this...every time I have my tv turned off for the day and when I get home and turn it on for the evenings viewing my convergence is all out of whack, meaning I have a double image...I can bring it back into focus but it goes back out the next day...anyone know what the problem could be and how much it might cost to have it corrected?
  • mindy26 Dec 16, 2007
    Yep. We are having the same problem, too. This is after sending back the first TWO TV's because they wouldn't even turn on. This afternoon the TV was fine. This evening, there is a red over white double image, top and bottom much worse then the middle. Tried to manually tune it to no avail. Any suggestions?
  • izzy1981 Aug 26, 2008
    I am having the same problem i can auto adjust it and it sometimes takes two times of doing the convergence to get it to work and then as soon as i turn it off and turn it back on its messed up again. I can watch two or 3 movies with no problem but when the set is turned off and back on it has to be
  • 4,402 Answers
Is this a RCA > HD52W56?
Posted on Dec 15, 2007
In some cases tv's with auto adjust on convergence that will not keep, some times the issue is you setting will not save. This turns the issue into something different besides convergence. One thing you can do is reflash the proper software on the unit, even if it already has the right software on it. Otherwise you may have to send it back for repair, shouldn't be to much 150 or less. Most of which is labor and jacked up prices. The parts are not to bad 10-40 dollars, good luck.....
Posted on Sep 11, 2008
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
May 04, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
The other day my wife was watching tv and suddenly
Ur convergence is dying or well be dead.3D pics or shutdown.U must know how to solders? The parts in convergence board must change like ICS,and all it resistors.The websites Tv Repair, for the convergence kit.The shop will cost u $300 for parts and labors.
Jan 14, 2010 | Proscan PS61670 61" Rear Projection...
TP61H95 Toshiba Cinema Series 61" The Image rolls
defintly the convergance.if the con is on a small board ,maybe 130 big board 250&up.if u know how to solder 35$ each STK and u need 2. and check each internal fuse with a ohm meter with tv power unplugged
Mar 12, 2009 | Toshiba TP61H95 61" Rear Projection...
It wont stop shutting off!
You can try the suggestion on the site I posted below. This site addresses a specific problem that tends to be fairly common in some Sony sets. Only try this if your sure that the problem your having is the same problem described in the site. Look at the picture of the screen on the site and see if that looks like your screen. The set on the site is red but it could be Green or Blue also. If you set won't stay on, you may have to turn the appropriate knob down slightly in order to get the set to stay on. Although he mentions this will fix a convergence problem, the fix described has nothing to do with convergence. The symptoms you are describing do not sound like a convergence issue. I am however a little concerned about the smell. Another thing is, after the set shuts off the Led will blink a code. For example it may flash 8 times then pause and repeat. You can Google this to find out more info on the problem. Many things can go wrong with TV's, I recommend you do as much research as you can to narrow it down. Good luck, here is the site.
Feb 26, 2009 | Sony KP-57HW40 57" Rear Projection...
VS-60111 turns off on its own after few hours
Did you repair the two leads? Ao check near the Convergence ICs for an open resistor or two, although that shouldn't effect your audio. Yu most likely have a low voltage regulator or bad capacitor. You will probably need the service manual to actually track it down. I will post a link where you can ge one for 12.99 and the include free unlimited support. They will also email it instantly to you if you return to the site and send them an email requesting they email it to you. You sound like you could fx it with the service manual and some guidance. Here is the link.
Jan 25, 2008 | Mitsubishi VS-60111 60" Rear Projection...
JVC convergencehas to be adjusted everytime the TV is turned on
You will need to enter servicer mode to do the alignment then
save is in service manual........
Does your set have an auto-focus selection ? Try that first...T.
Dec 26, 2007 | JVC AV-48WP30 48" Rear Projection...
Convergence has to be set daily
convergence amp ic are going replace them before you have more problems
Dec 12, 2007 | Toshiba 43H70 43" Rear Projection...
Intermittent losing blue on SD-643HD5 Pioneer
check the convergence area for bad solder
Sony Convergence
Nov 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
No Sound, No Picture
loose connection inside i would check the convergence amp area.
Convergence amp ic bad
Sony Convergence
Sep 23, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Picture is green and stays green
check the convergence area for bad solder connection
Sony Convergence
Aug 19, 2007 | Pioneer SD-643HD5 64" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
77 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
