posted by kalutumic on Oct 02, 2007
the pin from the garmin can be unlocked???????
2 Other Users Have The Same Problem
Comment by Guest, posted on Jan 25, 2008
my garmin nuvi 200 is locked out and im not living in the security area how can i fix this to be able to use my gps again
Comment by Returburk, posted on Dec 15, 2007
have the same problem. any solution?
Best Solution
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
how do i find out were tat location is if i didnt put the pin code
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 14, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
go to garmin website and downgrade your units filmware to any version before garmin lock then turn it on garminlock gone then let garmin update your unit through website thay will put the latest filmware back on it with garmin lock but no pass you can then set your own password .
give thxx...Json.warren
Solution #3
posted on Jan 23, 2008
If you forgot your PIN, all you have to do is go to the physical location where you originally set your PIN and turn the unit on (make sure antenna is up). It will not ask for a PIN and you will be then able to change the PIN to whatever you like.
Good Luck!
- Jim
Good Luck!
- Jim
Comment by sharcnet, posted on Jan 25, 2008
You got a good point CB. I'm trying to help these people and they can't drive to where they originally set the PIN at and reset the GPS? Or perhaps the unit was stolen and they just want to recover the PIN so they can sell it for $$. Thanks for the inaaprropriate vote MR. GUEST. What goes around comes around.
Suggest a new solution for this problem
Post a New problem for Garmin Nuvi 660 GPS Receiver
Email this problem
Email this problem
Can you Help with these GPS Devices problems?
Moving Favorites from 660 to...
I want to move or copy my... Answer This...
Foreign language text on GPS...
I just purchased a Garmin Nuvi... Answer This...
Problem with Garmin Nuvi 660
Hi, I got a message on screen... Answer This...
replacement battery for Garmin...
Did you find out how to replace... Answer This...
Nuvi 200w map download and sd...
I just bought the Nuvi 200w... Answer This...
Repair Service
Find GPS Device Repairman Near You:
