instead of the water staying in the machine to start the wash cycle,it's going out before it fills.what do you mean valid product? This is what's on the machine.
the drain hose is either a)not routed higher than the tub of the washer b)it is clamped tight to a drain hose of various materials c)too much excess drain tube is pushed into drain hose and extends all the way to botton of drain pvc.
See the installation instructions under drain requirements www3.sears.com
water indicator light showed container need emptying. found i could not get water container out as...
(More)
water indicator light showed container need emptying. found i could not get water container out as easy as before. after a few minutes to became free. i empty the water and try to reinsert the water container. i then found that something had either broken off or had work loose. sorry donot know correct name for this part.{ it connects to the water container that collects the water at the bottom of the dryer}.i was wondering could i buy a piece to fix my dryer and could you tell me the correct name for this part. i would be very grafeful for your help also thank you for taking time to read this. at the moment feel at a loss as i really relie on my dryer more so this time of year. once again many thanks.
i have a condencer proline dryer, the drum only turns one way and does'nt heat up at all, it stoped...
(More)
i have a condencer proline dryer, the drum only turns one way and does'nt heat up at all, it stoped drying just over a years old
maytag gas dryer, ignitor comes on, gas valve opens, ignites gas, runs for 30 sec the shuts down....
(More)
maytag gas dryer, ignitor comes on, gas valve opens, ignites gas, runs for 30 sec the shuts down. Replaced hi temp fuse & thermostat. What next?
