Question about Philips GoGear HDD1830 MP3 Player
"Please plug player into PC"
This girl in my class bumped into me and it fell out of my hand slammend to the ground. Now when I try to turn it on it says "plug player into PC" So I did and now it has the desplay on the screen of the computer communicating with the player. But I cannot put music on it. Windows media says please plug player in to complete this operation. (somethin similar to that message" So I am fucked unless someone awsome, incredulous and dazzling can help me out!
Re: "Please plug player into PC"
I have no idea what phillips device manager is i jus got this from
my brother and i have the same situation and im confused
Posted on May 29, 2008
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 19, 2008
0 characters
3 Points
I have no cd for my barbie girls music player. How can I find it on line to download.
you don't need the driver cd, you can just plug it into your pc and drag and drop mp3 files to it.
Apr 13, 2011 | Mattel Barbie Girls MP3 Player
I was borrowing my best friends mp3 player and i was on my back yard padio and it fell out of my hands. then the music stopped playing. i tryed charging it, pressing alot of buttons but it will not come...
When it hit the ground, it probably cracked/broke the circuit-board inside the case.
You could pay a qualified technician $25 to $75 to try to trouble-shoot it, but you'll probably get a "it is dead" answer.
So, you owe it to your friend to buy a brand-new MP3 player, as a replacement.
Apr 02, 2010 | Jensen SMP-115 MP3 Player
Barbie girls mp3 player. I cant find the volume control limit switch. I've seen it before when we first received this. Now my daughter wants the volume turned up and I cant find where to do it. Any...
You have a round button on your Barbie Girls Mp3 player. Right? Well, you have a round button in the middle of the circle that is Pause. On the right and left hand side is the back and forwards buttons. The up and down buttons on it is the volume control. Up is louder. Down is softer. Hope that helped you, deary.
Apr 21, 2009 | Mattel Barbie Girls MP3 Player
It fell n wont wrkk
you obviously broke a connection on it. Open up the case and see if anything is visiblly broken
Dec 23, 2008 | Nextar MA933A MP3 Player
Its not working
Maybe the hold button got knocked on the opposite side of the power button. try moving that and try to turn on again
Dec 11, 2007 | SanDisk Sansa m240 MP3 Player
I dropped my ipod after school once when someone bumped into me and it fell four feet to the concrete ground and now it won't turn on and i have tried reseting it and doing all the steps that i've looked...
Theres a spining drive inside the ipod. It's not spinning anymore. if it does not appear like it was dropped, and it's less than a year old, bring it to the Apple store for a possible free replacement.
Tell your friend to chill.
Oct 10, 2007 | Apple iPod nano
Won't power up
There could be due to a corrupted file, let us try to "Format" your device. Formatting will delete any existing corruptions in your MP3 player. To format your MP3 player, please do the following steps: Note: Formatting your MP3 player will delete all the files in your device, I suggest that you create a back-up copy of your files from your MP3 player to your computer. 1. Put the Hold switch ON, it's located at the side of the MP3 player (orange color should be visible). 2. Plug the MP3 player in your computer without the battery. 3. After it has been recognized by the computer, please open "My Computer". 4. Your device should appear as a "Removable drive" with an assigned Drive Letter (Ex: "D", "E" or "F"). 5. Right click on your Sansa MP3 player then select "Format". 6. On the format pop-up page, select "FAT" for the file system. 7. Click on ok/start. If you can't format your MP3 player at your computer. Please try it on a different computer. Note: If your MP3 player has a Firmware version 3.x and below please try the steps below: Also your MP3 player may have encountered temporary power loss. This issue usually happens when there is a failure of power going directly through the system of the MP3 player from the battery. Let's try to power-cycle your MP3 player. To power-cycle your MP3 player, please do the following steps: 1. Take the battery out of the player. 2. Hold the "Power/Menu" button for 30 seconds without the battery. 3. Try powering on the device. 4. Please try these steps for 3 times. I hope these steps help you resolve your problems regarding your SanDisk product. This is what sansa sent me when I had a similar problem. Good Luck!
Jun 05, 2007 | SanDisk Sansa m240 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
50 people viewed this question
Top Philips MP3 & Digital Media Players Experts
 Mike M
Mike M
Pieter Vleeshouwers
Are you a Philips MP3 and Digital Media Player Expert? Answer questions, earn points and help others
