You should be using this sort of thing in a motor vehicle ,here in spain its a big fine and points on licence if the radio can be heard outside the car with the windows closed ,but?? needless it doesnt stop the boy racers i like a car to be quiet especially my jaguar if i hear any noise from more than 4 ft away i sort it straight away .But yes i had the noise when i was young with my 3 lt ford zodiac and a record player that played 45s ,memories ? if this is a rear big boom boxx speaker the check the connections inside the unit sounds like a loose wire thats all
SOURCE: no volume from radio
way different vehicle then i own but when i blew the fuse on the factory amp i had no sound.... have a look at your fuse panel.
Robert
SOURCE: MY FACTORY RADIO VOLUME PROBS
More than likely with a 2003, the speakers that cut out are in the door or doors. Do they cut out of both speakers?
If they cut out of one, then you may have an intermittent speaker ( the wire to the cone becomes partially connected)
If both speakers turn off at the same time and you hear NOTHING on all speakers, then you more than likely have an intermittent connection on the radio itself and probably replacement is probably cheaper than fixing the radio.
One more thing
Factory radios sometimes have an amplifier in them. Sounds funny but they call the Radio in the dash the Head Unit and the amplifier is buried in the dash. You could have a bad amplifier or a loose power connection to it, but that is very unlikely.
Hope this helps.
E
E
SOURCE: 1988 Corvette Bose Radio Front Speakers only work periodically
try different speaker if works .its the speaker. if another speaker does the same .your radio is the problem.
SOURCE: Infiniti G35 speakers don't work
03 and 04 G35 vehicles had a Technical Service Bulletin issued regarding the audio circuit board. No sound was one of the symptoms of a faulty circuit board. There was a design flaw with the boards on the early model G35's that was corrected in 05.The audio units on those cars consisted of three pieces, the radio itself, which is just a silver box, a circuit board that attaches to the front of the radio and then the outer display. I would suggest contacting a dealership service dept. with your VIN number in hand, and ask if the circuit board has been replaced. Even if it has, It will still more than likely be the problem. It's either that or the radio
SOURCE: Truck Radio/CD Player, no sound coming out of speakers
Have you check the mute mode, maybe it is in mute mode.
