Question about TruTech TT1620 DVD Recorder
Black and white picture i did switch my setting to the pal by accident
I went to manual setup and didn't realize not to switch my tv setting to pal and i did but now it is in black and white and its causing my tv picture to run so i can't go back to set it back how can i let it reset itself to the original factory setting
  • Anonymous Jan 01, 2008
    Picture is black and white and can't figure out how to get it back to color.
  • 790 Answers
Set the palsecam or ntsc mode! or you have defective board video drive!
Posted on Oct 03, 2007
Bush tv / dvd combi modle .. led24127fhddvdp as started to play in black and white how cam I change it back
Make sure you have the correct country chosen in the initial setup. If the TV is setup for an NTSC country and you're in a PAL country or vice versa, the picture will be in Black and white.
Feb 08, 2017 | Bush Televison & Video
Connecting Virginmedia TV settop box to PC using Philips TV capture card. Result - sound and picture BUT black & white!!
You are either running NTSC into a Pal system or the other way around. Check the setup menu on the Virginmedia box to make sure what it's running, then make sure the TV card is running in the same format.
Hope that helps =)
Apr 09, 2008 | Computers & Internet
Why does it only play dvds in black and white
check color system settings pal to pal
TV PAL then DVD player has to be PAL
TV NTSC then DVD player needs to be NTSC
If mismatch in settings you may experience black and white
Dec 31, 2014 | JVC TH-A30 System
I have a hisense hd lcd tv and I tried watching a dvd on my curtis dvd1041 dvd player and it only plays in black and white
Check to see if the DVD player has a NTSC / PAL switch. For North America it should be in the NTSC position, if it is in the PAL position you will get distorted and or Black / White video. This could also be a setting in the setup menu instead of a physical switch on the unit.
Nov 08, 2014 | Televison & Video
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
A/V in black and white
good day,
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system.
most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto"
so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
Feb 01, 2009 | Sanyo Over-the-Ear Sleek Boom Microphone...
I can only record and play back in black and white.
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
No video in my philips dvd622
The black and white picture is caused by only 2 things.
  1. You are trying to play back an NTSC disc in a PAL dvd player (or the other way around)
  2. Your DVD player is set to NTSC when it should be set to PAL (or the other way around)
You will find options for setting PAL or NTSC in the setup menu under Video.
Apr 03, 2008 | Computers & Internet
Try going into player's menu, and set video out or TV type to NTSC.
It might have switched to PAL, or disc is PAL and player is set to any.
Dec 13, 2007 | Cyberhome CH-DVD 300 DVD Player
Black & White picture
There can one of two problems here. Either your DVD player's output is set to NTSC and you are attempting to play it through a PAL (European) TV, or you are perhaps using the SVHS output incorrectly. The solution is to access the player's setup menu and ensure the video output is set to your standard (PAL or NTSC). Hope this helps!
Feb 14, 2007 | Philips DVP642 DVD Player
TruTech TT1620 DVD Recorder Logo
88 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
