Question about Toshiba Office Equipment & Supplies
Gets hot shuts down its toshiba TDP-SP1 how can i resolve it?? do i need to change cooler?
  • 37 Answers
Make sure filters are cleaned. Use a vacuum so you don't spread dust around inside your projector. Make sure the projector can "breathe"; has room around it.
Posted on Nov 04, 2013
SOURCE:
Marrie
  • 563 Answers
SOURCE: Toshiba TDP T 91A
Hi there
I would suggest you investigate it yourself first before dishing out that sort of amounts.
Check if the fans are running.
Most of the times the overheating of a Projector is as a result of a faulty fan.
Posted on Mar 27, 2008
  • 7 Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
  • 5 Answers
SOURCE: HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Posted on Feb 01, 2009
projdoc
  • 2239 Answers
SOURCE: Toshiba TDP-SP1 Data Projector Pink Tint
go into menu and make sure input is computer and not rgb component. or just reset to factory defaults.
Posted on Jul 30, 2009
  • 120 Answers
SOURCE: need a control remote for a toshiba TDP-S8 where
1-800-remotes
Posted on Aug 24, 2009
Testimonial: "thank you."
Flashing light and then shuts down, the lamp and temperature bulb lights red on and off
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 07, 2014 | Toshiba TDP-SP1 DLP Projector
My TDP- T91A gets hot on one side is ther two fans in this projector or just one? I hear one fan but it seems to get pretty hot on the other side of the projector. I just received this and it is new to me....
Lamp life is affected by a lot of things. Is the projector mobile or is it permanent mount? How many hours a day is the projector on? There is no set time for bulb replacement. When it burns out it's a good idea to have a replacement already to go when needed. If the projector gets too hot, it will shut itself down as a safety precaution.
Jan 19, 2018 | Toshiba TDP-T91A DLP Projector
I keep getting a no pc signal even though I'm connected.
if you get no power, you'll need to replace the power supply. if you are just not getting a signal, reset the settings to factory default on the projector and replace the cable.
Oct 06, 2009 | Toshiba TDP-SP1 DLP Projector
"No signal" even though connected to computer
You probably have to tell the laptop to send a video signal to an external display--(i.e. <altF4 or <altF8) The proper function key will have a TV screen symbol on it. Default mode is "laptop only" By pressing and holding the alt, then pressing the appropriate function key, the laptop will switch to the next mode, laptop/external display. The last mode is external display only. By pressing the sequence again, you'll return to "laptop only" mode.
Sep 08, 2009 | Toshiba TDP-SP1 DLP Projector
Jul 30, 2009 | Toshiba TDP-SP1 DLP Projector
Problem with power point
These devices get hot when they work. they need cooling. if the cooling system get dirty and fan cant turn clearly then it stops itself for protection.  it need to be cleaned.
hope it works
May 28, 2009 | Toshiba TDP-T90 Multimedia Projector
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-P5 projector
Possibky is overheating... I would put a fan on it and see if the time-to-fail changes,
Oct 03, 2007 | Toshiba TDP P5 Multimedia Projector
51 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
