Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Water Leak Hello, My Kenmore coldspot (1997) refrigerator is working properly but I always see water leak to the kitchener fllor, would you know why this happened? Thanks!
  • Anonymous Oct 30, 2008
    I have the same problem my water dispenser however will not stop the water flow
  • markrundle Dec 23, 2008
    I get ice in the bottom of the freezer twice a week, on the same days.
  • 447 Answers
Do you have a water dispensor?? is there ice in the bottom of the freezer??
Posted on Oct 02, 2007
Water leak from my Kenmore Coldspot Frig Model 106. 59792990
U have a restriction in drain tube under evaporator coil. So every time it goes into a defrost instead of going down the drain tube it is running over and out the front of fridge
Mar 08, 2013 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
I have a Kenmore Coldspot Model 106.70182000 that is leaking water from the freezer into the refrigerator. Any ideas? Thanks!
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps you to stop that leak,
Gene
Aug 08, 2011 | Refrigerators
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Jan 26, 2011 | Kenmore Refrigerators
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
We have a 10 year old Kenmore Coldspot Refrigerator (it looks like model # 590 9990). It is leaking water from the freezer door. We turned off the ice maker to see if that would stop the leak but so far-...
look for all/any drain holes and blow out/syringe with clorine bleach ,then check door seals for any air leaks.water in fridge is mainly condensation from warm food/replacement air when you open door.
Jul 02, 2010 | Refrigerators
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
412 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
