Yahoo Mail Logo
w
wanda zyla Posted on Nov 04, 2013
Open folders I see my folders and when I click on a folder to see the messages in that particular folder, nothing happens. How do I access messages in a folder?
A
Anonymous
I think you can click after full page reload,so please wait for few times.
5 Related Answers
Anonymous
  • 392 Answers
  • Posted on Jun 10, 2009
SOURCE: I am unable to open any of my Yahoo mail folders.
it is due to the cookies or the cache...try clearing yours browsers cache , cookies and temporary internet files..... and reset your browsers settings ...
angel dust
  • 240 Answers
  • Posted on Jun 11, 2009
SOURCE: I can not open my yahoo e-mail without having to
Check your mouse configuration. Does it act normally on other programmes? As in using single click or doubleclick? Are you using yahoo main on the web or are you using it in Outlook Express and then opening your mail within that program? If using on the web there shouldn't be a problem if your mouse has correct config.
Anonymous
  • 838 Answers
  • Posted on Jul 16, 2009
SOURCE: Yahoo! Won't let me open my folders!
OK gud....try to install latest adobe flash player and as well as new yahoo toolbar.....than with All New Yahoo Mail....better luck..
Anonymous
  • 72 Answers
  • Posted on Nov 07, 2009
SOURCE: My Mail opens up in a total different format. I
search for a link named return to classic mail on the page, by clicking it you will reach the same old layout
Anonymous
  • 287 Answers
  • Posted on Jan 12, 2010
SOURCE: I can not view my email messages. I can see the
1. This problem is due to the busy Yahoo! Mail server.
2. Because of busy server all the features or options of any particular web page don't become enable!
3. Such a web page is not completely loaded on the web browser, and it produces errors!
4. You should try to Refresh / Reload the page to prevent this problem!
please rate this advice if it helps...tc! :)
Create folders
Click start all programs accessories navigate to windows explorer open.
Right click select new folder and name it.
tip
Windows Vista. Access is Denied error message when you try to open a folder or a...
Some of us may have encountered this error especially when opening folder like system volume information for example. You can take ownership of that folder, This is also helpful when you have just cleaned up your system of virus but you cannot open certain drives or folders.
You can also use this technique to disable the permissions of other administrators of the system so that no one but YOU can access the folder.
First I am gonna show you how to take ownership of folders. If you are looking for changing permissions to a disk drive, the please click here4809962.gif
if you are logged in as the administrator by following the steps below.
1)Right click on the folder and click properties.
2)Remove the read only check box and click apply.
3)Click on the security tab and click advanced.
4)Click on the owner tab.
5)Click on the Edit button since you want to edit the permissions.
6)This window should pop up. Select your username if you want exclusive access or select administrators to allow all administrators to be able to access it and check the box replace owners on subcontainers and objects.
7) A window will pop up asking you to confirm. Click YES.
8) A message will pop up asking you to close the folder and re-open. Click ok.
9)Close folder and re-open it and you will now be able to open it
Thank you for reading :)
Sai.
on Feb 19, 2010 • Computers & Internet
tip
Duplicate emails in Outlook Express?
When Outlook Express is configured for POP3 mail access it uses a file called pop3uidl.dbx to keep track of which message have been downloaded so that it can download only new messages. Sometimes this file becomes corrupted which results in the same messages getting downloaded again. So we will need a different copy of this file. Please do the following to recreate it:
- In Outlook Express click on Tools and Options.
- Click on maintenance tab.
- Click on Store folder button.
- It will open a small window with a path to the store folder.
- Copy the whole path.
- Click on start and Run.
- Click inside the run box and press Ctrl+V, it will paste the whole path we copied.
- Click on OK. It will open the store location.
- Close Outlook Express.
- In the folder that was opened, locate the pop3uidl.dbx file and right click on it and select rename.
- Rename that to pop3uidlold.dbx.
- Open Outlook Express and you will no longer receive any duplicate messages.
If you are using IMAP account, that can happen if your IMAP account is the default mail account and OE is configured to both open directly to the Inbox (which downloads headers automatically) and check for new messages when starting (which also downloads headers automatically). To stop the duplicates, simply choose one option or the other, but not both:
In Outlook Express click Tools > Options, then
1. Remove the check mark for When starting, go directly to my ‘Inbox’ folder
OR
2. Remove the check mark for Send and receive messages at startup.
If you already have duplicates showing, click Tools > Synchronize Account or Synchronize All.
Hi, I'm having problem opening my backup file from my USB that I copy from my old laptop to my new laptop. When I try to open the back up file their is an error saying: unable to open file. file maybe...
you need to to take ownership of a file or a folder then copy them over
How to take ownership of a fileYou must have ownership of a protected file in order to access it. If another user has restricted access and you are the computer administrator, you can access the file by taking ownership.
To take ownership of a file, follow these steps:
  1. Right-click the file that you want to take ownership of, and then click Properties.
  2. Click the Security tab, and then click OK on the Security message (if one appears).
  3. Click Advanced, and then click the Owner tab.
  4. In the Name list, click Administrator, or click the Administrators group, and then click OK.
    The administrator or the administrators group now owns the file.
To change the permissions on the file that you now own, follow these steps:
  1. Click Add.
  2. In the Enter the object names to select (examples) list, type the user or group account that you want to have access to the file. For example, type Administrator.
  3. Click OK.
  4. In the Group or user names list, click the account that you want, and then select the check boxes of the permissions that you want to assign that user.
  5. When you are finished assigning permissions, click OK.
  6. You can now access the file.
How to take ownership of a folderYou must have ownership of a protected folder in order to access it. If another user has restricted access and you are the computer administrator, you can access the folder by taking ownership.
To take ownership of a folder, follow these steps:
  1. Right-click the folder that you want to take ownership of, and then click Properties.
  4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of the folder, select the Replace owner on subcontainers and objects check box.
  5. Click OK, and then click Yes when you receive the following message: You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?All permissions will be replaced if you click Yes.
    Note folder name is the name of the folder that you want to take ownership of.
  6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
Network access denied
Follow the steps to Sharing the files
Your computers are already connected to a network — i.e., they’re all already able to browse the Internet using the same router..
1 : Open the Network and Sharing Center window by clicking on the Windows orb in the lower left corner, and then either right-clicking on Network and selecting “Properties”, or opening the Control Panel and double-clicking “Network and Sharing Center.
2 : If your network type is “Public,” you need to change it to “Private”:
  1. To the right of the network name and location type, click Customize.
  2. In the Set Network Location dialog box, click Private, and then click Next.
  3. In the Successfully set network settings dialog box, click Close.
3 : Under “Sharing and Discovery” in the bottom half of the Network and Sharing Center window, you need to turn all the settings from “Off” to “On” by clicking on the down arrow next to each setting, clicking on “Turn on …”, and clicking on “Apply.” But see some pointers below:
  1. For the “Password protected sharing” setting: you may want to leave this “On” or turn “Off” at your discretion. (I turned mine off.)
  2. For the “Public folder sharing” setting:
    1. If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    2. But if you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
4 : You’re done with the Network and Sharing Center window. Close it via the “X” button.
5 : Click the Windows orb at the lower left corner of your computer, and click on Computer
6 :
n the Computer window, navigate to the folder containing the file(s) or folder(s) that you want to share — e.g., “Pictures” or “Documents” or a specific file or folder within. Note: don’t open the folder itself that you want to share — just navigate to the folder that contains this folder.
7 : Right-click the folder that you want to share, and then click Share. The File Sharing window is displayed. (Click picture for a larger version.)
8 : If you have password protected sharing enabled: Use the File Sharing window to select which users can access the shared folder and their permission level. To allow all users, select Everyone in the list of users. By default, the permission level for a selected user is Reader. Users cannot change files or create new files in the share. To allow a user to change files or folders or create new files or folders, select Co-owner as the permission level.
9 : If you have password protected sharing disabled (like I do): Click the drop-down arrow inside the blank field in the File Sharing window, and select the Guest or Everyone account. Click “Add.” Then for that new account, click on the down arrow under “Permission Level” to change it to Co-owner (if you want anybody to read and modify files) or leave it at “Reader” (if you want other computers to just read but not modify your files).
10 : Click “Share”, then “Done.”
CRITICAL NOTE: If you selected “Everyone” when sharing a folder, you’re also making its contents available to any computer that joins this network. Many households, including mine, have wireless Internet via a wifi router. If you don’t have WEP encryption turned on, then I could just drive up and park on the street near your home, open my laptop, let it join your network via your wifi, and then nose around through your files. It’s particularly important that you have WEP encryption turned on for your wifi network.
Last night my friend sent me photos from our HS Reunion,when i clicked to download everything was fine all the way thru to when i clicked on open.I clicked on open the file started to download but the only...
You should of got an error message after it wouldn't open. Pls try to post it so we can see what happened. Sometimes the picture will be open down at the bottom of the email which you may not notice because your trying to work with the attachment. If you find them at the bottom, (it matters which format they come down in) right click/ copy/ go to my pics/ paste or save pic as/ then select destination folder. You can also click on the pic and it will ask you what you want to do. Anything that goes wrong 99.9% of the time will give you the error message. Very Important!!!
Cannot access any of my backup files
go on ebay you will get one on there for about a fiver mate
1helpful
I have dvd fab Platinum 4 have upgraded to dvd Platlum 5 got new key pasted entry in the space required it states will be reg but has not happened removed old version still will not reg thank you ...
Completely remove the traces of DVDFAB from your computer.
Clean Uninstall of DVDFab Platinum or Gold on Vista
1.) Uninstall DVDFab Platinum or Gold like you normally do.
2.) Click on Start open the your folder located on the top right side of the start menu.
3.) Open "Document" and delete both the "DVDFAB" folder and the "PCSETUP" folder now close the Document folder.
4.) On the on the menu bar click on "Organize" and scroll down and select "Folder and Search Options"and click on the "View" tab now scroll down and put a tick in the small circle next to "Show hidden files and folders" and click "Apply" then "OK".
5.) Now open the once hidden folder called "AppData" then open the "Roaming" folder and delete the "PCOUFFIN"...(Note)...there are 4 entries so delete all 4 and delete the "VSO" folder now exit the Roaming folder then the AppData folder.
6.) On the on the menu bar click on "Organize" and scroll down and select "Folder and Search Options"and click on the "View" tab now scroll down and put a tick in the small circle next to "Hide files and folders" and click "Apply" then "OK".
7.) Exit your folder and open the C: drive and click on Windows folder and click on "Prefetch"...(Note)...You will get a message stating "You do not currently have permission to access this folder" click the continue button and you will get another pop up message from "User Account Control" click the continue button now scroll down and delete the entry foe DVDFab will look something like "DVDFABPLATINUM.EXE-########.pf ( # ) are letters and numbers 8 in all.
8.) Now exit all windows and you are done.
Fox XP :
Check this :
http://club.cdfreaks.com/1711788-post1.html
Check the DMA.
http://forum.digital-digest.com/showthread.php?t=61905
Now restart the system for two times.
Install the new version of DVD FAB Platinum.
Hope this helps.
Good Luck.
Live, Love, Laugh.
Drafts will not open nor get deleted
Hello, I have had this happen to me and here is what i do to solve the issue. Go to your Drafts folder, open a message in that folder, now click Edit, then click Cancel Message, this will clear that message. Now just do that for the rest of them .. and you will be good to go. Hope this will help you Bob
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
