Question about Bosch Classixx WFL 2066 Front Load Washer
Have a Bosch Maxx 1200 (WFO 2460) front loading machine. drum has stopped spinning. Have taken the back off the machine, and confirmed that the belt is still on, and have observed that when the cycle gets to the spin stage, the motor is turning and that this is turning the belt and the big wheel connected to the drum, but the drum itself is not turning. Is it possible that what connected the big wheel at the back, to the drum, has broken or somehow become disconnected?
    Top Expert:
  • Bosch Master
  • 54,195 Answers
A common source of trouble in front loaders is the bearing that suppports the drum.
Posted on Nov 04, 2013
SOURCE:
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Posted on Dec 22, 2008
  • 3 Answers
SOURCE: Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
Posted on Apr 21, 2009
SOURCE: Bosch Maxx WFL2260
Here are the symptoms: - Wash cycle seems ok but can not be sure. When complete the rinse commences but am unaware what happens next. This is what I have done Started washing clothes and waited for cycle to end(!) or problems start. Switched off and set program knob to rinse. At this point I select spin and after a while the water starts to empty. When a sufficient amount has emptied I stop the spin (no spinning has began), and set the knob to wash again. This now allows clean water to rinse the clothes and when I think it has rinsed enough I set the knob to off then spin again until all the water has emptied. When the drum is empty the spin cycle should continue but does not. What happens is there is a clunking sound and the activity light goes out again, when it comes back on the machine tries to start the spin again and the sequence is repeated.
Posted on Jul 14, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
My Bosch Maxx (probably about 7 yrs old) was working perfectly till I opened the filter compartment (bottom right) to check it wasn't blocked. It wasn't. Put it back. Next time used machine there...
Bosch Maxx This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 28, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Got a Bosch WFO 2460, drum stopped turning, replaced brushes and cleaned up the stator but it still wont work. When it stopped the first time it triped the Mains circuit breaker so i am wondering if there...
there is a thermal cut out located in the windings on the motor you may have o hunt for this it has a wire going in and n out, you could short it out as a quick test if motor running....
Apr 22, 2011 | Bosch Exxcel WFO 2465 Front Load Washer
Awful bearing noise on spin.
Remove drum belt and spin drum by hand, if it is noisy or feels rough, then the main drum bearings have failed, which is a major repair.
Oct 11, 2010 | Bosch Exxcel WFO 2265 Front Load Washer
Bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Jan 07, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
BOSCH Maxx washing machine will drain and fill but not spin. Also recently clothes are left with sludge on them. Have put on several cycles with cleaning agent.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
Oct 08, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Beep sound
press the left menu button 4 times to get to the signal menu and press the right menu button until you get to OFF (for bosch maxx 2460)
Aug 15, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
412 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
