Question about LG VX8300 Cellular Phone
Camera When I try to use my camera, I get an error message. "camera starting fail" Thanks
By Z71kitty
Rank: Apprentice
Rating: 0%, 0 votes
Press your ok (menu) button.Don't pay any attention to what is on the screen,just press 000000 (6 zeros). This will take you to the service menu.Scroll down to #6 (H/W Test).Go to camera test and select on.Your phone will turn itself off and back on. Try your camera and see if it works.
Posted on Dec 25, 2007
  • 790 Answers
You have defective camera led sensor! replace a new one led camera.
Posted on Oct 03, 2007
HOW TO FIX CAMERA FAILED ERROR MESSAGE.HANDLER.HANDLE MESSAGE(-1)
ERROR HANDLER.HANDLE MESSAGE(-1)...CAMERA GALAXY YOUNG......!
Sep 12, 2012 | Samsung Galaxy Y
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
I get lens error M425-12 7f80 and when I test
When you get the message CCD calibration failed nothing can be done other than taking to service center to get your camera repaired . Professional help is required in replacing CCD in your camera .
Thanks for using Fixya.
Dec 08, 2009 | HP Photosmart M425 Digital Camera (5MP,...
SUBJ: JVC CAMCORDER DVL805. Error message...
oh me MINE did that exact same thing UNIT IN SAFEGUARD.. grrrrrrrrrrr.. YEP NEW CAMERA TIME.. sometimes they tell you that those battery cahrgers will work but it all really just defects them
Jun 11, 2009 | JVC Cybercam GR-DVL805 Mini DV Digital...
Can't start the SGH-G800 camera. Error message is ''camera failed''
I had this problem with a different samsung and the shop i got it from said i had a virus, i then rang samsung and they told me to downloads re-mapping software that comes on phones cd and reset it all. since then it has been fine.
Nov 20, 2008 | Samsung SGH-G800 Cellular Phone
Turn Camera Off error message
hi
I have the same error code if you can help me please let me know
thanks a bunch
Jun 29, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Memory card error - E50
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
"Connection failed." -- Serial connection
The "Connection failed" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
LG VX8300 Cellular Phone Logo
217 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
