Question about E-Machines eMachines Desktop PC
E Machine operating system not found - cna't get to the bios - Ran XP Pro installation and it keeps rebooting after first phase of formating drive. I think the drive might be dead - However was able to put it in a different machine as a slave drive and get to the files to copy to an external drive. Not sure how to fix. Tried to fix the boot recorded and the mbr - to no avail.
    Problem Solver:
  • 18 Answers
If your not able to get into the bios, your problem may lay there. Since your bios tells your computer how to run (as you probably already know) then it may not be telling your computer how to run. Try testing the battery on your board with a voltage tester, or just buy a new one. Try a few different things and try to get into your bios (like disconnect all drives). If you think your hd is dead, run a hd test with your computer as a slave. You can also try using a program Norton partition magic to scan the drive and see if its alright. (very powerful program). Make sure you do a full scan on it to make sure that its not physically damaged, like the mbr being permanently damaged by the drive becoming unbalanced. Good luck
Posted on Oct 05, 2007
SOURCE:
My Sony Vaio laptop has no operating system because my hard drive died. I have a brand new 160 GB SATA hard drive. Tried reinstallation of Operating System with Sony's recovery disks, did not work. Also...
new hard drive needs to be formatted before software can be installed on the hard drive. you need to use advanced setting on the software installation, and then format hard drive.
Jul 31, 2017 | Sony VAIO VGN-AR190G Notebook
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
How to format compaq presario cq40-301au window xp service pack 2
shutdown ur pc and reboot right on start up start tapping F10 until recovery screen shows click advanced options and follow directions. if you can get xp pro sp3 i suggest it!
Nov 14, 2009 | Microsoft Windows XP Professional With...
I am trying to format c: and erase everything on that drive i dont have a boot disk however just the windows xp pro disk and i cant remember how to get into command prompt
You can't format the drive while Windows is running. Insert the CD, reboot, and follow the prompts to delete and re-add the main partition, then do a Quick format.
Nov 02, 2009 | Microsoft Windows XP Professional With...
I want to install xp by removing my pre installed vista in presario cq61-132tu. and there is no option of sata in bios so plzzzzzzzzzzz help me. i want to operate only xp means i m not want to install both...
Put XP disk in CD-ROM and reboot the computer.
Click yes to install XP. It will tell you there is a system already installed on C drive. You select to install XP on C drive. It will ask if you want to format C drive, you select full format.
XP will then install
Sep 24, 2009 | Compaq Computers & Internet
My computer was fixed by a person who installed xp pro on it but he didn't have a validation key. Well i found my original install cd with the xp home edition and i want to do a clean install to install...
really simple just turn put the cd in turn off the pc and reboot, your cd drive should pick it up on boot up from there its simply following directions
Jun 24, 2009 | Computers & Internet
NO OPERATING SYSTEM FOUND AFTER I JUST LOADED XP HOME AND ALL THE UPDATES FOR IT ?
Put your windows disc in the drive and reboot. It should allow you to boot from disc and then you can install as per on screen instructions.
You have basically erased the hard drive and the OS
For future reference, just put your install disc in and reboot, you will be given an option of upgrade, or install. By installing you will automatically format the drive.
May 07, 2009 | Computers & Internet
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
Driver to Floppy? Won't Fit? Going Crazy...
Before you install drivers you must first install operating system to do this check BIOS is set to boot from cd then insert Operating system cd and reboot. When operating system installed then install motherboard drivers and any others that are needed
Jul 22, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
E-Machines eMachines Desktop PC Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
