Ok, i got the tv for free..... but the lamp and housing is gone and im not sure if there is any thing else wrong with it. who or where is the best place to talk to someone. im not going to put alot of money into the tv but i would like to try and fix it . do the off brand light bulbs last as long as the ones you would get from the factory. TV will not turn on at all or light turn on, on the front of the panel, could this be from the light bulb and housing being gone? i have done some searching could it possibly be the lamp engine??? any one have any good advice let me know. Thanks
You can get a lamp and a door for the lamp, but I would suspect something else is wrong with the set. You are correct, the set will not power up without the door in place, but, the lights on the front should be flashing telling you the door is missing. I would try to locate a local repair service and find out how much they would charge to diagnose it
Let me know if this helps.
SOURCE: mitsubishi 62525 wont turn on
You can get the lamp and housing at the following link for your model which is the origional oem lamp and housing at a fraction of the cost that they normally run. You have to click the contact link on the lower left hand column and tell them your model and what youre looking for.
http://servicemanuals.vstore.ca/
