Question about Garmin GPSMAP 498
Depth display The depth reading from the 498 is about three feet different from the reading of the depth gage on the boat which I know is correct. At high speed the 498 doesn't record dept also.
  • 2 more comments
  • slrIII Nov 08, 2007
    My Garmin 498 has the same problem at high speed. The depth begins to blink and not record the depth.
  • Anonymous Dec 26, 2007
    Gps 498 Where the dpeth is displayed keeps blinking 1.0 ft. .Doesnt record any depth or show the bottom contoure . thanks allen
  • Anonymous Mar 31, 2008
    When boat gets onto plane, the depthfinder flashes and stops reading accurately and the bottom configuration no longer shows.
  • Anonymous Mar 23, 2014
    depth reading freezes up on screen at 2.4'
  • 790 Answers
Reset your factory settings!
Posted on Oct 03, 2007
X105C unit only works in very shallow water less than 10 feet. Every now and then I might get a deep water reading when idle but 99% of the time the depth display just blinks indicating not able to get a...
When my depth finder acted like this I found out it was the sender that had not done well over the winter and was giving me false readings especially when the boat was at speed. The sender and cable only cost around 30 or $40. The hard part was since I have a pontoon boat getting under the Pontoon and replacing the wire in the spring when the water was cold.
Jul 01, 2017 | Lowrance X105c Dual Frequency Sonar
I have a fishfinder Hummibird 565, I use it on a big fishing boat which is impossible to fix the sensor on the bottom of the boat, so I tried to hang it on the boat with a float, but it cannot work well,...
you can get a specialist to come and fix/reapply the sensor to the boat and possibly fix it if it is broken var fctb_tool=null; function FCTB_Init_4fdf0f4e4d1b403489dd188ff9311fa0(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_4fdf0f4e4d1b403489dd188ff9311fa0(document['FCTB_Init_3475a15565eb478ea69972d3c6d88377']); delete document['FCTB_Init_3475a15565eb478ea69972d3c6d88377'] var fctb_tool=null; function FCTB_Init_a70c5362962d40be976e65b2158646e3(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_a70c5362962d40be976e65b2158646e3(document['FCTB_Init_379c2b6472d1424f847e6d43703fa3ad']); delete document['FCTB_Init_379c2b6472d1424f847e6d43703fa3ad']
May 05, 2011 | Sport & Outdoor - Others
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Want to know depth range just bought boat with this unit know nothing about it
with the correct transducer you can mark fish at 600 and bottom at 100 feet
Jan 31, 2010 | SI-TEX Sitex Cvs106lmkii Color Lcd With...
Lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Jul 28, 2009 | Boating
Bought a 1995 Four Winns boat inthe dash it has a lowrance dept finder. under dash i see a 6pin male round connector & 2 pin round male hareness is there a harness i need to connect the 2 or what would...
Hi- I have a 1996 Four winns boat with the same problem. I believe we are missing an adapter cable which goes from the depth cable to the instrument panel. I have not been able to locate this cable yet. If I find it I will let you know and can you do the same for me if you locate one?
Jul 03, 2009 | Lowrance Boating
Lowrance x96 does not function after 20 feet depth
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
May 26, 2009 | Lowrance X96 200khz Fishfinder
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Jun 18, 2008 | Furuno GP1650DF GPS Receiver
Garmin GPSMAP 498 Logo
387 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
