Question about Ricoh Aficio Colour 3006 Color Copier
A3 paper What is the best A3 120 gsm paper for photocopying artwork?
  • 163 Answers
A3 size best is 1 90 to 100 grm
Posted on Oct 05, 2007
SOURCE:
Scuff/score lines down print plus central grip mark
Possibile solutions
1) Complete cleaning using copressed air or lint free cloth
2) check the cleaning blade on your drum (Round Glass cylinder)3) Change your drum unit
4) replace rollers
Oct 10, 2013 | Canon Pixma Ix6550 A3 Inkjet Printer
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
I have a copier IR2270 it makes paper jam on A3 all the time, what will be the problem?
I experience that a lot of times too , but I use Epson . Well , I'm not really expert to this thing .
maybe this site can help you : http://www.canoncopiers.co.uk/photocopiers/discontinued-models/canon-ir2270-photocopier-printer.html
Aug 19, 2011 | Computers & Internet
What's the name of a canon printer that can print A3 size bond paper?
There are many A3 Canon printers, but let me mention two, one's the cheapest and the other one of the most reliable.
1. Canon BJC-5100 is the cheapest and one of the smallest A3 printer ever. It costs around $50.
2. Canon Laser Shot LBP3500 is another reliable and affordable Laser A3 printer. It costs around $850 to $900 (prices may vary).
These are not the only available Canon A3 printer, there are many more, you'll be able to find the best suit for your needs and requirements. Almost all printer supports bonded papers (like executive bond), there's nothing to worry about, but note that some don't support Photo paper or Thick/heavy paper.
For more details visit the canon website (click here to find out more A3 canon printers).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 02, 2010 | Canon BJC 5100 InkJet Printer
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
A4 size
I'm not sure what a MP5000 is... Is it a Minolta EP-5000? With a ARF-9? If it is you may have a sensor problem or it could be the two one way gears that drive the paper feed rollers in the doc feeder..... Can not be sure if that is the model you are asking about... It may also,be one of the sensors in the doc tray.. I'm also not use to A4 & A3 paper sizes.
Aug 27, 2009 | Office Equipment & Supplies
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Paper in tray but message says paper tray empty
HP officejets are notorious for problems with paper feeding...
Try the solutions (ignoring the ones about tray #2) from this solution... They're all the same sort of printer feed mechanism.
http://www.fixya.com/support/t878735-printing_error
... also something I noted with the K850 (the earlier model to the K8600).. some papers are less likely to be picked up than others.
I had to get some cheap A3 paper for that unit which worked better than Xerox branded, higher quality photocopier stuff. Sounds strange but if it works...
Hope that lot helps.
Feb 22, 2009 | HP OfficeJet Pro K8600 Printer
Ricoh 420 SC270 error
i want to solve this problem of sc 122 code in my photocopy want can i do to remove this code. because i can copy the A3 papers even to resize A3 to A4
Jul 17, 2008 | Ricoh Office Equipment & Supplies
Open Questions:
See all Ricoh Aficio Colour 3006 Color Copier Questions
50 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
