Question about Infinity BASSLINK Car Subwoofer
Basslink drops out.
I have a new Basslink that worked fine for a few days. Now it comes on for about 5 seconds after I turn on the stereo, then just drops out with the power light still on. I have 8 ga. power and ground wires. The power wire goes directly to a power distribution block by the battery. The power light stays on when the unit drops out. I have an auto on and off wire hoked to the white power sensor wire on my amp. The car is a 2000 BMW 528i. I used speaker level wiring and tapped into the 12 pin plug on the amp. Any suggestions? Thanks, Curt
  • lagerball Dec 19, 2007
    I have installed an Infinity Basslink in my car with no problems. However after a year the basslink makes what is described on their web site as a thumping then 'motorboating' noise. They say this could be due to the following:-
    1. Are the power and ground leads are the correct gauge.
    2. The speakers or speaker wires are not shorted out.
    3. Determine if the voltage to the amp is to low.
    4. Check to see if any fuses are blown.
    5. The alternator may not be powerful enough.
    The power and ground leads are the correct gauge, the speakers are not shorted out, no fuses are blown and the alternator has been upgraded from 65amp to 90amp recently although it worked fine with the 65amp for over a year. Therefore I think it could be point 3. Has anyone else had/solved a problem such as this before, if so please could you tell me how you did it.
The auto on switch should only be in the on position when the REM wire is NOT connected. Auto on can be flaky. Basslinks respond better to RCA inputs then the high level ones. You might try getting an RCA line converter, they work very well with the Basslink.
Posted on Dec 06, 2007
SOURCE:
Basslink works for a few seconds after i turn on the stereo, then it fades away. The servo light is always on even when i disconnect the input line and turn the knobs to the min level. What could be wrong?
Hello, check the +15v and -15v on the Switching Power Supply Control board. If one or both are missing, it is probably Q117 for +15v and Q118 for -15v. If one is missing the limit comparator will rail to one side and cause the auto variable volume control to trip the servo protection.
Oct 02, 2010 | Infinity BASSLINK Car Subwoofer
Power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
Oct 07, 2007 | Infinity BASSLINK Car Subwoofer
I have a JBL1004 amp in my ski boat. I killed the battery listening to the stereo and caused the battery to lose a cell and drop to 10 volts. The stereo cut out as one would expect. I have replaced the...
if the protect light comes on then you might not have enough voltage running to the amp so you would need to add a second battery just for that amp.
Jul 26, 2010 | JBL GTO1004 Car Amp
Phntom bass sounds
uhhh....try you change your wire setup
Sep 17, 2008 | Infinity BASSLINK Car Subwoofer
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
Jan 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink "Motorboating"
Good evening, my name is Colmen here is a guy that might be able to help you 917 504 0461 please let me know how you make out, he has done a lot for me, by the way his name is Cee...
Dec 19, 2007 | Infinity BASSLINK Car Subwoofer
Basslink II problem running off speaker input
Definately a wiring issue. Go to this site and backtrack to see where you went wrong. hope it helps.
http://www.ehow.com/how_5829_wire-car-stereo.html
Dec 12, 2007 | Infinity BassLink II Car Subwoofer
Light is always on!
yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery. the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo. hope this help u....
May 09, 2007 | Infinity BassLink II Car Subwoofer
Basslink intermittant
i posted similar prob. servo lights when power is being cut to speaker (over drive) and manual shows it for purpose of tuning gain. it should flicker at highest input only...mine is on always too. infinity wasnt much help since mine is out of warranty.
Nov 13, 2006 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
347 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
