Question about Brother IntelliFAX 2800 Laser Fax
Outgoing fax makes loud clicking noise
As paper feeds (force necessary) for outgoing fax, machine makes loud clicking noise. Drum has been changed with no results.
  • MMint Dec 03, 2007
    Have a similar problem with a Brother 4100e. We get a clicking sound whenever we receive a fax or print something out. Put in a new drum to no avail.
    Scholar:
  • 159 Answers
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Posted on Dec 24, 2007
SOURCE:
Black streak down right side of outgoing received fax
clean the scanner, it may have white out or some other obstruction blocking it
Jun 02, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Outgoing faxes are black.
just copy a paper if copy is black ur scanner is dirty or dead .first clean scanner with tissue other wise change it.if copy is ok result not black that is due to telephone line.by mian jee
Dec 15, 2008 | Brother IntelliFAX 5750e Laser Fax
Outgoing Faxes
THE MACHINE IS ET TO DELAYED TRANSMSSION (MAYBE THROUH TOLL SAVE BUTTON ) OR OTHERWISE, PLEASE CLEAR THE MEMORY STORED MESSAGES FOR DELYED SETTINGS, THE PROBLEM WILLL BE RESOLVED IMMEDIATELY HAPPY FAXING OMNIPRESENT
Jul 31, 2006 | Samsung SF-830 Plain Paper Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
414 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
