Question about Whirlpool RBD245PDS Electric Double Oven
Control Panel I am trying to replace the control panel. Does anyone know how to remove the face plate on this oven?
  • Anonymous Nov 27, 2007
    Control panel doesn't work
  • 447 Answers
Yes actually i do..... open the lower oven door next to the hinges are 2 small phillips screws, securing two long metal side trim pieces. remove trim. Exposes two more phillips screws Control lifts up and off then Make sure unit has been powered down !!!!!!!!! If the old control is totally blank there is a thermal fuse that has gotten too hot. PLEASE rate my solution...Thank you
Posted on Oct 03, 2007
How do you remove the face panel for the control buttons. My on/off button needs replacing.
Jenn Air Oven Remove Front Panel - YouTube
? 1:46
https://www.youtube.com/watch?v=cEKlbFxONMI
Jan 27, 2012 - Uploaded by travisgrindal
This is a video describing how to remove the front panel off a Jenn Air ... Do you have any for changing the wirings in the back? for the oven ...
How to remove an oven keypad...Part 2 - YouTube
? 10:46
https://www.youtube.com/watch?v=-ACCdMbIvJM
Aug 12, 2012 - Uploaded by VideoJoeKnows
Part 2 Removing an oven keypad is easy...when you know how. ... to have a friend help you with this, but if you need to do it yourslelf, that's fine ...
Safely Removing a Microwave Oven's Control Panel ...
Dec 08, 2015 | Ovens
Viking double oven control panel labels rubbed off
The control panel face can be ordered from Viking Range unless the unit is very old, then I would suggest partstown.com, You will need the model and serial number from the rating plate on the unit. These parts are usually not very expensive and are really easy to replace.
Hope this helps....GOD BLESS...Randy...
Feb 02, 2012 | Viking Designer DEDO130 Dual Double Oven
The screen says F7 and an alarm keeps beeping
One of the most common problems with GE electric built in ovens is the error code "F7′ shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the "search" button and in the new window type the word "control panel" in the "search by keyword" box and click the "search" button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Oct 25, 2010 | Thermador SC302T Electric Double Oven
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    Can you tell me how to replace a faulty switch on a Zanussi Electrolux ZCE5001X double oven. It's the switch on the control knob for the main oven.
    Under the control panel you will find 3 screws which holds a heat deflector plate,remove this plate remember position.then under this are some more screws for control panel,make sure power is off.take knob off main oven switch then pull panel forwards there may be screws in side of panel check for these.On the back of the multiswitch for oven is the oven thermostat it just pulls off if you prise with a screwdriver.Then remove the 2 screws holding the switch in place get new switch and wire for wire change over wires be very careful its easy to forget where they came from.Put all back in reverse as you took apart.
    Hope this helped.
    May 17, 2010 | Ovens
    My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
    I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
    Nov 21, 2009 | GE Ovens
    Control panel buttons due not work
    It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
    1. Turn off the breaker at your house's breaker panel.
    2. Verify there is no power to the oven.
    3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
    4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
    5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
    6.Slide the front panel off.
    7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
    8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
    9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
    email me for pics schmidtkeith1@yahoo.com
    Aug 31, 2009 | Maytag 30" Built-In Single Electric Wall...
    Built-In Oven Buttons Stop Working
    Email me for some pictures:
    Aug 02, 2009 | Maytag 30" Built-In Single Electric Wall...
    Oven mystery....need the best GURU or Wiz....CHALLENGE! Please help!!!
    was the thermistor that connects to the heat board replaced?this is the bulb inside the oven that monitors the heat,it should have 2 wires going to the board.try wiggling these wires and see if it starts to heat,if so the thermistor is bad.
    Jan 06, 2008 | GE Monogram® ZET3038 Dual Single Oven
    Whirlpool RBD245PDS Electric Double Oven Logo
    416 people viewed this question
    Top Whirlpool Ovens Experts
    Sal De
    John Tripp
    John Tripp
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
