it is due to 60Hz HUM IN POWER SUPPLY. please check for input supply. also check for mains filter capacitor in tv. also check for one diode open in rectifier ckt.
when TV first switched on picture is narrow across middle of screen. after upto 10 min picture...
(More)
when TV first switched on picture is narrow across middle of screen. after upto 10 min picture widens to full screen. model toshiba 3387db. a
Toshiba 3377DB: My TV will not switch on, although when I push the on switch it appears to be off...
(More)
Toshiba 3377DB: My TV will not switch on, although when I push the on switch it appears to be off but it is making a hissing noise as if it is going to switch on. I have check the 2 internal fuses I can find on the PCB there are working.
tv keeps going on standby have to switch off for few secs then on then its fine for 1.2.3/8hours...
(More)
tv keeps going on standby have to switch off for few secs then on then its fine for 1.2.3/8hours then goes off
tv toshiba 2987db is stick on standby tv switches on ok then goes on standby then the green light...
(More)
tv toshiba 2987db is stick on standby tv switches on ok then goes on standby then the green light under the stanby light starts flashing have to get up switch it off till lights go out then its fine for few hours can u help
