Question about Philips 107E56 17" CRT Monitor
Monitor i just moved my computer to a new house and when i set it up the colors on the screen look weird not like they usually do. You can still tell what the colors are but its light colors, the screen looks a yellowish/greenish light color. And when i cant get into my menu on the monitor because its in spanish and it says the menu button is blocked. is there a way to unblock the menu?
  • 24 Answers
Try pressing the menu button and holding for 15 seconds or more. I have heard this will unlock most locked menus.
Posted on Oct 03, 2007
SOURCE:
Monitor keeps going blank, then once this a.m. it cycled in colors, white, red, green, blue, grey- very weird... what's up with that?
it's doing testing in color codes to refresh the color on the screen, if it keeps going blank, that's usually a sign of monitor going bad.
Oct 16, 2009 | Westinghouse L1928NV Monitor
Weird colors!
Normally this happens if the plug at the back of of the monitor or the computer loose. Try to secure that cable. If they are secure, check the pins on the ports at back of the monitor / desktop or the cable. I also suggest that you try a different monitor cable.
Jun 17, 2009 | LG 22" FLATRON LCD Monitor
Color is not correct
First I would check to see if there are bents pins in the connector. Secondly, this usually only happened with the old CRT monitors when they got moved near a location with high magnetic field.
Mar 27, 2009 | Mag Innovision InnoVision LT 565 15" Flat...
SCRAMBLING SCREEN
befor replacing,make sure settings in video output from video card are set for that monitor.If color quality is set too high or resolution settings not supported by the monitor are used picture may not show up at all.(try safe mode,Settings are usually at bare min.in safe made)
Jan 09, 2009 | Acer AL1715 17" LCD Monitor
Screen is now a weird color
The problem might be in the cable. Try to reconnect it to your machine. Also try to set your color settings on the monitor itself, so that all the colors are equal.
Sep 26, 2008 | LG Flatron L1750S 17" LCD Monitor
Discolouring of monitor
There are several reasons for this most likely is the vga cable from the video port has undergone stress (sharp bending or crushing) this damages the cables inside and causes one or more of the colors to not display, usually red and or blue. odd it seems the green always is left unharmed when I see this...weird.
If you can I would replace the cable from the monitor to the computer. if the cable is sealed in then you may be able to find a replacement at a service center. and they could replace it for you
Apr 30, 2008 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Monitor gets brighter
Well... it's time for a replacement. It's seems your AD Board begin slowly to dies out... Eventually will turn to white screen.
You'll need a new AD Board.
Mar 10, 2008 | Fuji FP-768 17" Flat Panel LCD Monitor
Dell m992 screen problems
If you notice, when you see the windows start screen, its usually "big and dopey". Thats because the video drivers aren't being used yet. If it is blanking out right after you see that screen (with the scrolling bar), my guess is it's a corrupt / bad video driver.
Was any other hardware added recently?
Jan 10, 2008 | Dell M992 19" CRT Monitor
Dell M922 monitor problem
To change the resolution back to something more reasonable go to the control panel (start, settings, control panel) and double left click on the Display icon. Click on the settings tab. The color quality should be set a high as possible, usually 32 bit or true color. Then click on the Advanced button in the lower right corner and on the next screen click on the Monitor tab. In the Monitor settings make sure the Screen refresh rate is set between 70 and 75 Hertz (the higher the number the less obvious the screen flicker will be but don?t set any higher). Click on the OK button to go back to the previous screen. Once that is set you want to increase the Screen Resolution using the slider bar to the left. For a 19? screen you would want to set it to a minimum of at least 1024 x 768. The typical setting is 1280 x 1024 depending on monitor / video card capabilities and personal tastes. Once you get the resolution back to the original settings your screen will display as it did before the ?change?. If you find another resolution setting you like better we?ll need to make some adjustments to the monitor itself. Just let us know. Ordinarily screen resolution changes doesn?t just happen, it?s usually the result of a program, user or problem. If that is the case you?ll need to post anther question along with details about what is happening just before the change occurs along with your operating system and any other pertinent information.
Mar 18, 2007 | Dell M992 19" CRT Monitor
Philips 107E56 17" CRT Monitor Logo
183 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
