I recently replaced the bulb in my tv and i have not yet reset the bulb timer. I do not have the original remote and can only access setting on the front of the tv...
The tv had color for about a month after replacing the bulb it looks great i was playing Xbox on it but all the sudden it just went BLACK AND WHITE....no color and i'd like to repair it myself if possible.
ANY SUGGESTIONS???
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
SOURCE: LG 50inch Plasma received loud sound then went black
My friend's LG 50" plasma tv has the same problem and it cannot light up. The picture and sound are working fine. But the brightness is too low. It is purchased 2006 too and out of warranty. So I opeend up and found 9 capacitors 3300uF 10V on the power module at the middle of TV are popped. I am planing to replace all of them. They are available at digikey.com. I think this model's power module has design flaw. The cap rating may to low. 10V? Stay tune to see what happen after I change the all the caps.
SOURCE: lg tv problems ru44sz63d It turns on to a
http://www.retrevo.com/support/LG-RU-44SZ63D-TVs-manual/id/371ci555/t/2/
http://www.eserviceinfo.com/index.php?what=search2&searchstring=J52A+(projection)
Above are links for your service manual, and a training manual.
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
