Question about Dryers
Washing machine temperatures
What temperatures are used by the settings on USA washing machines described as cold,warm and hot. The launderette i use in the UK uses USA machines, but the UK instructions on my clothes give temperatures.
  • 447 Answers
Usually high setting is off at 155 F medium 140 low 125 PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Posted on Oct 03, 2007
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
211 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
