Question about Refrigerators
Refrigerator Freezing I have a Sear's Side by Side Refrigerator 106.50542001 made by Whirlpool. The Refrigerator side has been freezing since replacing the Condenser fan unit with a universal motor. I then replaced the Thermostat control unit. The Refrigerator compartment unit is still freezing. The Freezer section goes below -27 and the Refrigerator section goes to 10 to 18 degrees very quickly. I have to shut the unit off to warm it up. Changing the Temperature settings in any direction does not amount to any increases in the refrigerator compartment.
  • Anonymous Mar 19, 2009
    Neither side is working now.
  • Anonymous Mar 20, 2014
    I have a g e refrigerator model PDS20SBSBLSS.the condenser fan has 4 wires w,r,b,&y. the other side of the plug has 3 wires w,r,&r.i need to know how the 2 sides match up, ie which colors goes together?
    New Friend:
The damper is stuck in the open position that freezes the top compartment and freezes the water lines and filter on the top shelf and will crack it. Move things down lower and shut off water till you fix.
Posted on Nov 26, 2010
Thank You to (the Dr's) suggestion that there may be a damper problem. This made me rethink and open the system up and reverse the clockwise motor direction of the universal condenser moter. This corrected the freezing problem that I was having in the refrigerator compartment. A repair man told me my fan had to be in the clockwise rotation when it actually needed to be in the counterclockwise postition.
Posted on Oct 03, 2007
  • 447 Answers
Your refrig has a mechanical damper (the a b or c knob) it may be broken (uncommon ) \ is the freezer fan running even if the cold control is cycled?? Other than that it must be a faulty cold control These are very reliable refrigs and your problem is interesting. Please rate my solution
SOURCE:
Whirlpool ed25rf refrigerator side freezing on bottom
your evaporator motor may be going bad also check to see if your condensing unit and fan motor are clean this can cause similar problems.
Dec 11, 2013 | Whirlpool 25.2 cu. ft. Side-by-Side...
Items freeze on top shelf of refrigerator. All temps are per factory specs.
If it is only freezing on the upper shelf then you will need to replace the "air diffuser". It is not closing when the refrigerator temp is reached. Here is the part to order.
Nov 05, 2012 | Whirlpool GSC25C4Ey Side by Side...
My Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator bottom meat section and veggie drawer is freezing my meats and vegetables. Why?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not freezing or cooling
The clicking is probably the starter/overload relay which starts the compressor. If the relay is good then the compressor is bad. Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Aug 30, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Admiral refrigerator is freezing every thing up
Hi. thanks for the question .The problem is with the thermostat control .I would replace it . thanks the appliance doc
Jul 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
365 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
