Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Lens trouble canon powershot sd 550
Hi! I had my sd550 in my pocket. When I put it out and switched it on, the lens of the camera was obstructed and LCD screen went blank and showed E18 in the left below corner and did´t work. Then I tried to star it again and I couldn´t, its stucked. Can somebody help me? Tks Mar
Check here...http://www.fixya.com/support/t102982-e_18_problem
Posted on Oct 12, 2007
SOURCE:
Lens won't retract on SD550
Try resetting the camera by removing the battery for 20 mins. then replace the battery go to the camera's menu and set the Date and Time.
May 28, 2012 | Canon PowerShot SD550 / IXUS 750 Digital...
TROUBLE SHOTING
blurry, out of focus,image fomation,problem of the focusing unit of the lens unit ,while taking a snap,half click the camera button,till u get foucus indicator blinking GREEN light,then click,if not service the lens unit/replace the unit.
Mar 06, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
My lens for my canon powershot SD550 is stuck open.when switching the camera power on E18 appears on the screen in the bottom left corner.
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here are some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try.
Nov 15, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
I dropped my Powershot SD 500 and now the lens cover does not cover the lens. It leaves a gap when closed and does not retract all the way when open. It seems that the resolution on some of my photos is...
A bit of gentile persuasion may be necessary.
Have you tried to push the lens into the camera body?
I believe that the camera has lost track of where the lens is in it's range of travel.
use your finger and see if a small amount of pressure will put the lens back ito position.
In the end, this is not a new camera, if it is dead a better replacement can be had for as little as 120 $US
Jul 27, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
My canon sd550 lens are not going down and when i try to take a picture it makes a funny noise and comes up with a blank screen
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 15, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Zoom not working for my canon Powershot SD 550 Digital camera
 Seems like the motor has burned out
A reaiar is not a likely economic move
Check out Canon support
Sep 23, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
133 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
