Question about LG KG320 Cellular Phone
Voicemail My phone is saying that I have voice messages, but I check and there are none that I haven't listened to. The problem is that there is a pop-up on the main screen notifying me of this at all times. It's very annoying.
    Sergeant:
  • 452 Answers
If u are getting these types of pop up then YoU need to contact 1ur service provider's helpline and u will get the proper soltion whether there are any voice messages for you or not.
2.I f there  are no messages then reset the settings of your handset.
All the best.
Posted on Oct 23, 2007
SOURCE:
I have a tracphone. How do I clear my voicemail box? No messages can be left on my voicemail. Thank you.
Delete voice mail by going through the keypad on your cell phone. The actual procedure depends on the kind of cell phone that you own. For example, on the Nokia 1100, hold down the "1" key while you are on standby. Tracfone connects you to your voicemail, where you can follow spoken menu instructions to listen to your voicemail. After you hear the voice message, you're asked if you want to delete your recordings.
This is not recommended, because connecting in this way uses up your minutes even if you just want to listen to them.
Use your landline phone to delete messages if you want to avoid using your Tracfone minutes. Turn off your cell phone so it doesn't ring and then call your cell phone number from a landline.
Press the "*" (star) key as soon as you hear your voice mail greeting. Then enter your password number and press the "#" (pound) key.
Listen to the instructions for accessing your voice mail, which can vary slightly depending on the phone you have. You are told the number of new and old messages you have, how to listen to them and how to store or delete them. Press the number for listening to the message to hear it, and then the number for deleting.
Sep 08, 2017 | Lands Phones
How do I get my voice mail?
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Feb 02, 2014 | Vtech DECT 6.0 Digital Cordless Phone
How do i listen to a message on a panasonic kx-dt321
You're subscribed to a voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 03, 2012 | Lands Phones
Hi how do i setup my cell for voicemail
using your cell phone (make sure battery is fully charge) call voice mail and when prompt entered password if you have already set it....and listen to the voice (prompts) it will most likely say you don't have any messages, but do wish to set or change your outgoing message press the appropriate key when prompt and listen to the options to set
Nov 11, 2010 | Sanyo PRO-700 Cellular Phone
Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Nov 23, 2009 | Panasonic KX-TG1033S Cordless Phone
Listen to voice mail
Those messages are on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 06, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Voice Message Icon always displaying
The voice mail symbol is sent to your handset by the network when you get a voicemail, they then send the handset another message to remove the icon once you have listened to the voicemail... Sometimes an error occurs and the phone doesnt receive the removal message...
Try getting a friend or using another phone send yourself a voicemail, then using your phone, check your voicemails, listen to the one you have and delete it... The icon should go... However if its a hardware fault with the handset display then this will not fix it...
May 07, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Voicemail Icon
I had the same problem at one point in time. However, I figured out that when someone calls and leaves a voicemail there is a message that appears saying "1 new voicemail". Try hitting the "listen" option and let it take you to voicemail that way instead of cancelling out of that option to see your missed call. That should make it go away. If not, then I have no idea.
Aug 06, 2008 | LG CU400 Cellular Phone
"NEW VOICE MAIL" is stuck on screen
what you do is call your own phone number it will tell you to set up a voicemail account and make a 4 digit pin ....once that is made you can listen to the prompts to listen to your voicemail and erase the messege and the phone will get back to its normal self hope this helps
Feb 17, 2008 | GE 25932 Cordless Phone
New Voice Mail
I have FiOs and used some of the info I gathered from this page to get my voice mail working now! To set up my voice mail I called my phone number (from the house phone), then pressed * when the automated system picked up...Your prompted to use a 4 digit pass code, which is the last 4 digits of your phone number (worked for me). From there I listened to the prompts and created a new "4 digit pw" as well as a "name password" by the end of the cycle. It then allowed me to listen to the messages on the phone and delete them! Phone finally says ready on it.
Oct 07, 2007 | GE 25952 Cordless Phone
LG KG320 Cellular Phone Logo
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
