Question about Cherokee Jeep Grand CD Changers - 10-Disc
Jeep alternator Hi guys,I have a 1991 Jeep YJ,it stopped one day on my way home, I thought it was out of gas, but ,,had lots of gas,so I put a new gas filter on it,put new 'O' rings on the injectors,put in a new battery,and it still will not start, it tries VERY hard to start sometimes it seems it catches , then it is getting gas at the injector site.I have tried 'bomb'starting it that didn't work either. so i am think by process of elimination it needs a new alternator ?? BUT I am not a mechanic , I just use my book for it and try to figure it out.Thank you for your time and any assistance. Lorraine
  • 883 Answers
Re: jeep alternator
I cannot diagnose your Jeep with given info, but I can answer your question...NO, a bad alternator will never be a problem for an engine to not start, especially not after a new battery. Possibly cracked spark unit that allowed water to penetrate and fail it. Spark can be intermittent after this fails. Check it by removal and inspect for crack. Have you tried using "starting fluid" into the air intake manifold or is that what you mean as 'bomb' starting?
Posted on Oct 03, 2007
0 characters
3 Points
Error code P1763 forinstance this guy needs to replace both the sensor and the solenoid
and perhaps mod it like the dodge guys have done
its a bad governor pressure sensor
looking here you'll find the issue
and checking out this error its common to dodge also
there is also other mods to the transmission to stop it happening
{you need to paste this into the browser}
but this is the error
you replace it and clear the code
Apr 19, 2015 | Jeep 2004 Grand Cherokee Laredo
I just bought a2007 jeep commander the other weekend and just the other day I backed out my driveway and the check parking assist came on the dash pushed on the gas and nothing felt like there was no gas...
If you just purchased it from a dealer it should have a warranty for a few days. If it does take it back and let them deal with it. Could be cheaper in the long run.
Mar 18, 2015 | Jeep 2007 - Commander
Burning much gas
The cause is that the Compass is too heavy for any of the engine combinations offered. Further, and especially in the case of the 2.4L, the engines are far from efficient even when used in appropriately weighted vehicles.
This is the least effective product that Chrysler/Jeep has ever offered - not only my thoughts, look around (at non-Chrysler/Jeep websites).
Chrysler/Jeep does NOT have a reputation for selling vehicles that are economical - and a tank weighing some 4600lbs with only 175 horsepower (and that's with the 2.4L) on SUV-tyres should not be expected to do any better than 30-40 mpg. I'd be surprised if your mileage wasn't more realistically around 50mpg, since the ratings system used in US is somewhat 'generous' to the manufacturer.
May 16, 2014 | Jeep 2011 - Compass
Vibration and engine smells
sounds like u have a fuel injector malfunctioning get some sea foam injection cleaner available at any parts store put the recommended amount in your gas tank and see if that fixes your problem
Nov 02, 2012 | Jeep 2004 Grand Cherokee Laredo
I have a 2006 Jeep Grand Cherokee Lerado every time I put gas in it, the next day my check engine light comes on. I just had a Tune up and they flushed all the fluids and filled them with fresh fluids the...
I went through this routine with a Ford Escape and eventually a Ford dealer found the fuel pump was failing mechanically and had to be replaced. Hope this helps point you to what to check.
Sep 21, 2012 | Jeep 2006 Grand Cherokee Laredo
I have a jeep liberty that just had a new battery put in and now the cd changer won't work. any suggestions
Alternately, try opening the CD changer door, ejecting the CD carrier and look for a small reset button below the opening. Press this with the tip of a pen and hold it for 10 seconds, then turn the radio/CD on again.
May 19, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
Jeep grand cherokee-check engine light and oil gage not working
does anyone know how to change from radio to cd stacker on a Philips ministero p.t.
N / 61 / 01208 / 22837 / A
D.M. 25/6/1985 / 27/8/1987
90 RC 348 / 53
made is singapore
these are all the numbers i can find on it
e-mail address is
or Rae Delamere
08 8268 8672 mobile 0107 47 041
i would be very greatfull
Nov 29, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Car CD Changers Logo
219 people viewed this question
Top Cherokee Car CD Changers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Mark Schmit
Mark Schmit
Are you a Cherokee Car CD Changer Expert? Answer questions, earn points and help others
