Question about Lowrance Iway 500c GPS Receiver
Since updating to 1.8 we need some instructions on using the new screens.
After updating, we haven't been able to use some of the older version screens. There are new screens that we can't get to. Are there any instuctions on the new screen?
  • 149 Answers
Re: Since updating to 1.8 we need some instructions on...
It sounds like you are not the only one with an issue on this upgrade. This sounds like a firmware issue. Please notify your manufacturer regarding the situation ASAP so they can work on resolving this issue with possibly another firm ware upgrade. This is a software issue... Let me know how that goes and what you find out so we can proceed. Also, I've worked for a projector manufacturer who ran into similar issues with upgrades, they need to know in order to correct the problem.... Good luck and talk to you soon!
Posted on Oct 02, 2007
0 characters
3 Points
How do I update my Tom Tom GPS on computer?
    1. To check for an updated application version do the following:
      1. Connect your TomTom device to your computer and switch it on. ...
      2. If HOME does not automatically check for updates, click Update my device in the HOME menu. ...
      3. If a new application is available, it is listed on the next screen. ...
      4. Click Done.
      More items...
      How do I update the software on my device? - TomTom TomTom
  1. How do I update the software on my device? - TomTom
    TomTomAug 28, 2015 - To check for an updated application version do the following: Connect your TomTom device to your computer and switch it on. If HOME does not automatically check for updates, click Update my device in the HOME menu. If a new application is available, it is listed on the next screen. Click Done.
Dec 25, 2015 | GPS Devices
I own the Kenwood DNX7140 navigation system. Periodically the screen says "Software Update Complete" and teh system locks up. I have never updated teh software though. What is wrong with it?
You need to update your software. Garmin does this through a downloaded file you burn to a CD. You then do a firmware update to the Kenwood from the CD. Instuctions are on-line at:
Jan 12, 2010 | Kenwood DNX7140 Car GPS Receiver
Tomtom does not respond to touching the screen. Sometimes a red X flashes on and off. I have tried to reset it. Makes no difference. Tried to go on the Tomtom website for repair instructions but it will...
i don't get the point.
Doesn't your touch screen work, or TT menu frozen?
If frozen menu, then update it to new version or older version.
if screen trouble, you need to get TT touchscreen calibrator. If you don't know, bring to waranty.
Feb 23, 2009 | Tomtom ONE GPS Receiver
GO720 Map Update problem
It appears that this problem was a case of non-backwards compatability with maps to application versions. My gps was on v8.02 application which was not compatable with the v8.15 series of maps. I had to remove ALL the software off the gps, allow it to rebuild using TomTom Home up to v8.300 and then re-load the v8.15 maps. This then stopped my older maps from working.......
I can see this working in a commercial sense; ie every time there is a gps version update everyone will need to purchase new maps, but jeez it's bloody frustrating!!
Dec 30, 2008 | Tomtom GO 720 GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
My garmin nuvi 200
To view the current firmware version, complete the following steps:
  1. Turn on the GPS.
  2. Switch to the tool kit page by touching the tool symbol on the buttom row.
  3. Touch "Settings".
  4. Touch "System".
  5. Touch "About"
  6. Thesystem will display the firmware version at the top ("SoftwareVersion"), the unit ID on the second line, followed by variouscopyright information.
  7. Touch "Back" to return to the previous page.
For online updating you must have Webupdater
After installing WebUpdater once from the Garmin website, perform allfuture software updates from your computer. Simply connect yourcompatible Garmin device to your computer, then run WebUpdater fromyour computer's "Start Menu" by selecting "Start", "Programs","Garmin", and finally "WebUpdater".
Attention! It were cases that unit software newer than on Garmin site and it were losings of local language support after online updates. You must deside before do you need these changes of firmware or not so important.
Sep 27, 2008 | Garmin nuvi 200W GPS Receiver
Why can't update the firmware of streetpilot C330 ?
I would suggest getting in touch with the Garmin tech support. You may have to send the unit back for a hardware fix. There were some issues with new updates in some of their older products.
If the unit is working okay and you see no issues, you may find better value to leave it alone, and over time save up for a newer unit. If you look at their new NUVI series, these are far improved from the generation of the one you presently have.
Jerry G.
Jul 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Bluetooth intermittant connection problem
Have you rechecked with garmin webupdater there is a new update since july 1 2008.
Jun 21, 2008 | Garmin nuvi 350 GPS Receiver
Current location error
Do you have the back up map of usa? If so you can format the sd card in a card reader from the computer, and reinstall, did your update update tomtom home to version 2? As there are some glitches caused by this update, it may be worth reverting to an older version of TTHome,
Dec 29, 2007 | Tomtom ONE GPS Receiver
Lowrance Iway 500c GPS Receiver Logo
35 people viewed this question
Top Lowrance GPS Devices Experts
buzz flewhart
buzz flewhart
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Device Expert? Answer questions, earn points and help others
