Question about Olympus D-565 Zoom Digital Camera
Olympus D 565 digital camera
Both lights in viewfinder started blinking indicating no, or low power. Replaced rechargeable batteries and still got the same. Camera would not open and could not view pictures already taken. Hooked up an AC adaptor to power camera and still get the blinking lights. Any hope for this camera?
  • 255 Answers
SOURCE: AC Adapter Question
Check the polarity. Having a 5060 (fabulous camera in my opinion) I chose to buy a couple of extra batteries rather than go the adapter route. They are cheap at eBay, Tiger Direct and other places (I don't know what's available to you in Spain) , and give you added backup for a heavy day or two of shooting.
Posted on Sep 13, 2005
silly girl
  • 513 Answers
SOURCE: olympus sp 350
Are you sure you finalized the firmware upgrade procedure according to the instructions? This sounds a little like you pulled the plug a little too soon... Have you done it according to these instructions: And kept the camera connected until the update was 100 % complete? If you did everything right, try reseting the camera - take the batteries out for the day, and see if it helps. if you're back to step one(the reason you did the upgrade), try the firmware upgrade again. If still it doesn't work contact olympus, and I hope you have a valid warranty. Good luck
Posted on Jun 25, 2006
  • 107 Answers
SOURCE: broken camera
It is likely that your lens assembly was knocked out of alignment when you dropped the camera. When things do not line up inside the lens the whole unit cannot move in and out. This malfunction requires disassembly to fix, so you will have to get it to a professional for repair. There are providers online who can repair your camera, and also check with your manufacturer to see if they can service the camera at a reasonable rate. David Millier Advance Camera Repair
Posted on Mar 06, 2007
SOURCE: Batteries fail in very short time
I had the same problem but I fixed it by buying 2 rechargable CRV3 batteries and the charger. At the time such batteries were not common, so although I got a brand that I never heard of (CTA) and they have been great, They last a long time and power is no longer an issue.
Posted on May 21, 2009
  • 155 Answers
SOURCE: Olympus E410 viewfinder problem
As far as I am aware, you can use the viewfinder OR the live view, but not both at the same time.
This is because a mirror has to flip up out of the way to reveal the sensor for the live view to work, and the mirror needs to be in the down position to reflect the image into the viewfinder.
Switch between the two modes and double-check if there is a problem.
Also try removing the lens from the camera and checking the position of the mirror. It could be that it has got stuck in the up osition.
Hope this helps!
Posted on Jun 27, 2009
I go to charge the battery and it looks like it charges for a while then the charger red light starts blinking. I put the battery back in the camera and the battery is still flat. Not sure what's wrong?...
The blinking light on the charger indicates that the battery needs to be replaced and will not charge. You can buy a replacement lithium battery online at sites like Amazon for less than $10.
Nov 18, 2010 | Olympus Stylus 820 Digital Camera
Mar 22, 2009 | Olympus SP-350 Digital Camera
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at...
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Dec 16, 2008 | Olympus FE-170 Digital Camera
Problems with camera
Hi everyone,
I found you because 10 minutes ago, my camera exhibited the same behavior as all yours. All of a sudden, the red and green lights started blinking on and off and nothing worked. I just tried switching batteries and the camera is working! I am using a couple of RCR-V3 Li-ion rechargeable batteries, which I purchased on Ebay three months ago. Thought I'd pass it on.
Take care,
Jul 17, 2008 | Olympus SP-350 Digital Camera
Olympus Camedia C-2020 Zoom - always reads low battery and then "dies"
Safe way - Try using brand new and fully charged NiMh.
Not for novice - Battery contact points may need cleaning. Use contact cleaner with a cotton swab.
Do not try - Spraying contact cleaner or WD-40 in battery compartment.
Last option - Service center.
Mar 08, 2008 | Olympus Camedia C-2020 Zoom Digital Camera
Olympus Camedia D-565 Problem
you left it too long for a free replacement
But it is worth contacting Olympus as it is know this one was a lemon.
Jan 15, 2008 | Olympus Camedia C-350 Digital Camera
D-565 Jammed
Take the batteries out, and let it sit for a couple of hours, doesn't always work, but sometimes it does.
Sep 12, 2005 | Olympus D-565 Zoom Digital Camera
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus CR-V3 long-life lithium batteries (LB-01) will provide approximately 500 shots. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
When batteries are low and they are not used for a period of time, they can build up enough voltage to give a full battery indication. The batteries only had enough power to shoot one image. The batteries are exhausted and need to be replaced or recharged.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Olympus D-565 Zoom Digital Camera Logo
57 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
