It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below. Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
RADIO OPERATION 1. TURN THE VOLUME ON / OFF (15) CLOCKWISE TO TURN ON THE RADIO. 2. SELECT THE AM OR FM BAND BY THE WEATHER BAND/AM/FM SELECTOR (13). 3. TUNE THE STATIONS BY THE TUNING (14). 4. ADJUST THE VOLUME BY THE VOLUME ON/OFF (15).
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off.
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off. This should take care of the problem.
This is an easy fix with a can of volume knob cleaner i think its called. You should be able to get it at radio shack. You just spray it into the volume knob and let it dry. The instructions are on the can.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
first of all if you live in a cold climate I never turn the radio on until the car warms up if you can remove the knob on the radio spray a light amount of WD 40 and then put the knob back on and turn it back and forth and if you have pop on your hand or water also dry your hands off before touching the radio the lights and the radio will last a lot longer also and also before leaving the car always remember to turn the radio off it will be alot easier on your battery as well
Check the grill in front of the speaker area for debris or plugged holes. Check the transmitting radio for debris blocking the mic hole. When turning volume up on the radio, do not max out the volume knob, back it off slightly for best sound. If these do not help, your radio is probably malfunctioning and needs replaced.
