Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
D-link DIR-635 router
I have tried to install the router at dynamic ip address as I am broadband cable. When the set up is looking for internet connections it tells me it has a problem when trying to access the internet. I have disconnected the moden numerous times and reconnected but to no avail. I access the internet with no problem when not using the router
  • 5 more comments
  • tepuli Nov 02, 2007
    I have the same problem that my new D-Link Rangebooster N650 fails the setup process to my laptop. It says it, '.... cannot connect to the internet contact your ISP'.
    Forgot to add that I tried the advice suggested below of pinning down the WAN speed to 10Mbs but still it does not work
  • Apans Nov 04, 2007
    I have the same problem i can't use the internet when i conect the modem to the router.
    i use D-Link DSL-320T as the modem and D-Link DIR-635 as router.
    Please help me!
  • Skalken Dec 04, 2007
    I have the same problem, with the same message telling me to contact my ISP. But the fault does not lie with them, since I can connect fine without the router. I've tried the following:
    1) Logged on to DIR-635 at IP no. 192.168.0.1
    In status/wan window released and renewed connection severeal times, new IP Addresses are then assigned, but it still does not work.
    2) Turned off power to DIR-635, waited 5 min, turned on again, same situation.
    3) Used the "reset" button to factory settings. Configured DHCP connection manually. Didn't help.
    (I should perhaps mention, that I have temporarely disabled the wireless function, so this problem applies to my connection through cables)
    Any help is highly appreciated,
    Sincerely
    Ingo Milton
  • Anonymous Jan 05, 2008
    I got excatly the same problem. I tried to change the IP to 192.168.0.99, only resulting to that the router dissapered from my computer. Tried also to lock the WAN down to 10Mbps, with no changing whatsoever only that the connectionspeed was much lower. I am using a Speedstream Ethernet adapter with a samsung Xpresslink router. Still, doesn't seem that thats the real problem
  • xiaoxiao Feb 15, 2008
    My problem is the same:
    When I try to install the router and use the software in the CD, everytime I come to the step where the software is trying to connect to the internet this message pops up:
    "A problem has occurred when trying to access the Internet. Please check your DSL/Cable connection and verify your Internet connection settings"
    I have no problem with the internet connection when the router is not attached. I can't install it through the Browser either, because the connection goes off and on all the time... someone who can help me with my problem?
    I can say that my Internet connection is cable, and I have been using a switch to connect to my two computers I have, if these information are helpful...
  • Ney Jan 06, 2009
    I´m going nuts with my D-Link DIR-635! Whenever I use a wired desktop connected to the router, while another wireless computer is connected too, the network/internet connection drops almost immediately. I can use 2 or 3 wirelesses computers at the same time and have no problem. But if I start my PC wired LAN the whole network drops. ANd the it starts a connect/disconnet cycle, almost endless. And it´s been like that since for several weeks now, tried new firmware 2.24EU and it does not solve the problem. Now I installed and old DIR-514 and everything is perfect, no connection drops with my wired PC, and 2 - 3 other wireless devices at the same time. Off course the wireless speed is lower, but I solved temporarily my headache!
    New Friend:
Hello
Please give me a valid link
Because the link { ftp.dlink.de/dir-635/driver_software } does not work
Thank you
Posted on May 09, 2013
Install the latest firmware from here ftp://ftp.dlink.de/dir/dir-635/driver_software/
Now everything work perfectly for me (pppoe).
Posted on Oct 31, 2008
Ok ppl...Try to copy MAC address of your basic ethernet (laptop / pc / etc) to your router, and then change it. [on your computer so no conflict were seen] Later try to connect your router to modem . greetz
Posted on May 02, 2008
How I have solved my problem with the wired computer to a DIR-635 router:
- downloaded latest firmware from ftp.dlink.de/dir-635/driver_software (as posted here before)
- reset the router ( keep just the power cable connected to the router, press the reset button and switch off/on while holding the reset button pressed, off/on again with reset pushed down, release reset button, connect LAN cable between PC and router, access router 192.168.0.1 and all the configuration using the wizards)
- while configurating your Internet connection (I have the wizard option) it is important to use the option "clone MAC address from your PC", the one you used to connect direct to the cable modem.
- Follow next common steps to configurate your wireless network, etc.
Right now I'm having my PC wired to the router plus three other desktops via wireless and a wireless Canon printer.
Everything is working fine, no network drop, no internet drop. Perfect as it used to be.
Posted on Jan 06, 2009
I can´t get the DIR-635 to work with Pppoe.
Any ideas?
Posted on Dec 27, 2007
    Brigadier General:
  • 6,966 Answers
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Posted on Oct 05, 2007
SOURCE:
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
How do i setup the 3g wireless internet on the dir 412?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
Also:
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router.
Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
Step 3 Power cycle the cable modem and router:
  • Turn the cable modem off (first)
  • Turn the router off
  • Leave them off for 2 minutes**
  • Turn the cable modem on (first)
  • Wait until you get a solid cable light on the cable modem
  • Turn the router on
  • Wait 30 seconds
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-412 Mobile Broadband Wireless...
I installed my D-Link DIR-615 router today and did my setup in my Window 7 laptop. I don't know whether it matters whether I do setup in a laptop or a desktop. Then, I connect the modem/router to my...
If you have trouble connecting to your modem, you may need to lock the speed down on the WAN port of your router to 10Mbps. Within the web-based configuration utility for the router, go to Tools > Misc and the option to select the WAN speed will be towards the bottom. Not all routers have this option.
Follow the steps configuring the router once again...
Step 2 Click the Setup tab and then click the Internet button.
Step 3 Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address from the drop down menu. Click Clone Mac Address. Click on Save Settings to save the changes.
Step 4 Click on Status. Under WAN, Click DHCP Renew. If it does not get an IP address or times out, then continue with the next step.
Step 5 Power cycle the cable modem and router using the following steps:
Turn the router off
Turn the router on
Wait 30 seconds ..
Step 6 Follow Step 1 again to log back into the web configuration. Click the Status tab and click the Device Info button. If you do not already have a public IP address under the WAN heading, click on the DHCP Renew button.
Jan 22, 2010 | D-Link DIR-615 Wireless Router
D-Link DIR-635 Wireless N Router won't install
hi! I will be more than glad to assist u in this concern. I encounter that problem as well. I have a dlink as well. I follow the cd installation and it wont detect the modem or internet. but if the computer is connected to the modem it works..what i did. i didnt follow the cd installation, I set it up manual by typing at the url of your brower, 192.168.0.1 that is the ip add of the router and it will ask the username and password, by default the username is admin and the password, just leave it blank..in the setup page, select on manual internet connection setup.. there is an option for dhcp-which is auto detect, static ip or pppoe. but first check what kind of setting u have with ur isp, if u are using a username and password, u have to select the pppoe, if the isp provide gave u a static ip address u have to select static.. to know your ip address settings, click start, run and type cmd and it will show dos prompt, from there type ipconfig/all, it will list the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Aug 01, 2009 | Computers & Internet
DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
May 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I have installed 2 delink routers for my Mac, I still cannot get on line. the mac is new, what is the problem?
Try to configure the DIR-625 wireless router. Connect your computer to one of the LAN port to one of the router. Then access the IP address of the router (192.168.0.1) configure as dynamic IP then clone the MAC address. Make sure that you modem is connected to Internet port section of the router. Check the Internet connection after the configuration leave the other behind check the connection of the main router before installing the other one.
Mar 10, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have just purchased a dlink dir 635 router and am trying to set it up on my Bigpond cable broadband internet. previously I had only a Motorola SBG900 gateway between cable and pc. I now have the new...
The motorola sbg900 is acting as a router itself. I'm assuming this is what you've got? http://promo.bigpond.com/homenetwork/html_new.php
So first, go into your d-link router settings and make sure the THIRD number in the IP address is the same as your modem's ip address. This third number is the "subnet", and it must be teh same for both router and modem.
e.g. if your motorola users ip 192.168.2.1, make sure your d-link is set to 192.168.2.2. Make sure the fourth number is different, but the 1st 2nd and 3rd numbers are the same.
You can figure out what your motorola's ip is by connecting it to your computer, make sure your interent is working, and then run "ipconfig" from a command prompt window. Look for the "Default Gateway" IP. That's your motorola's ip address.
Once the IP addresses match, go into your router's settings and disable the "DHCP server".
Next, plug a network cable to go from one of the LAN ports on your motorola to one of the LAN ports on your d-link. Note that it is LAN port to LAN port. The "internet/wan" port on the d-link is never used for anything.
At this point your d-link will be operating like a "Switch", it knows it is just an extension of your existing network and it won't collide and cause you problems like it was before.
Dec 06, 2008 | Computers & Internet
Cannot access the internet through my DIR-625
Check your IP address to 192.168.10.1 on the network settings
after that turn modem and VoIP off.
Click on Setup / Manual Internet
Select Dynamic IP under "My internet connection is"
Click on "Clone Your PC's Mac address"
Click on Save settings, if it ask for reboot click on reboot
After the router reboots (NOT COMPUTER), it will take you back to the router.
Once your are in the router, turn the modem on first then the VoIP.
After the modem and VoIP has finish rebootin
Click on the status tab of the router and check uder the "WAN"
Settings and check the IP address. If you get an IP address then check the internet.
If you do not get an IP address Click on Release and then renew.
If you still do not get an IP address click on Advance tab
Click on Advance network on the left and turn UPNP off and save the settings.
After that it should be able to get an IP address and you should be able to get online.
Nov 05, 2007 | D-Link DIR-625 (790069292637) Wireless...
DIR-635 can't access the internet
I think you have wrong configuration of your router.
1. Some xDSL Internet Service Providers may assign a Fixed IP Address for your Broadband router. If you have been provided with this information, choose this option and enter the assigned IP Address, Subnet Mask, Gateway IP Address and DNS IP Address for your Broadband router.
2. If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must choose this option and enter the required information.
Nov 04, 2007 | Computers & Internet
Computers & Internet Logo
12,197 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
