Question about Pentax Optio 50 Digital Camera
Setting up Digital Camera as web cam
I have a pentax optio 50 digital camera. And I know it can be set up as a web cam to but I can not seem to figure out how to do it. I have windows xp. I can get it connected to download the pictures I take off of it. But I can not seem to get it to work for a web cam. Any help would be greatfully appriciated. Thanks in advance
  • Anonymous Jan 10, 2008
    I have the same problem. In addition, the battery life is so short that it runs out of power before I can figure out how to make it work as a video camera. I need to find out how to get an AC adapter, so that I am not relying on the batteries.
    AG
I can't get mine to run as web cam either, but run it from mains power with an adapter I got.
Its a small transformer with variable voltage and I set it to 3volts or whatever and then plug in the appropriate connection out of the range of connectors that came with the transformer (its thin and long).
Even then the connection is not very good and I need to make sure the camera stays still or it looses power.
Posted on Sep 29, 2008
SOURCE:
Focus not working
Set your camera to factory default settings and try it again. Make sure it is not on Macro setting.
May 19, 2010 | Pentax Optio 50 Digital Camera
What is pentax optio z10 reset button
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
Jan 29, 2010 | Pentax Optio Z10 Digital Camera
How do you reformat the camera
I can't send you the actual PDF of page 160 of the Optio W10 manual thru here, but here is the link to that manual on the Pentax web site: http://www.pentaximaging.com/support/manuals-and-literature/
Sep 12, 2009 | Pentax Optio W10 Digital Camera
Pentax Optio E10
Hello. i think you can help me more than i can help you. Can you please send me the win xp drivers for optio E 10? You can send it to [email protected]
Apr 18, 2009 | Pentax Optio E10 Digital Camera
Need a driver for vista/ pentax optio 60
I need webcam driver for vista.. pentax optio 60 my e-mail [email protected]
Jan 08, 2009 | Pentax Optio 60 Digital Camera
Pentax optio l 50
1.first switch off the camera
2.then take out the battery
3.clean the inside with a dry and clean cloth
4.again switch on the battery
5.try to select the white balance option again
6.if not,do the process again
it will surely work
Sep 24, 2008 | Pentax Optio 50 Digital Camera
Major blurring/sharpness problem with Pentax Optio 50; help!
Thanks for posting the photos.....they tell a lot. You need to return that camera and get a refund. The camera is defective. The first two photos were taken under good lighting conditions and you should have gotten good shots. The last two were taken at low light and the camera was using 1/30th of a second shutter speeds which could account for some blurring due to camera movement. The last one appeared to be a flash shot and it selected 1/30th second. Not a good thing for the camera to do. But all photos have the appearance that you are shooting through a fog. And all photos were shot with an ISO setting of 200. There is something wrong with this camera for that to happen on the first two shots. I checked the EXIF data that is embedded in the photos. That gives you the shutter speed, aperture setting and focal length, ISO settings, and other information. I have not seen a review of the Pentax Optio 50. But the older S50 did not get good reviews. If I were you, I would look for a different brand of camera. For a few dollars more you can get a Nikon 5600.
Aug 30, 2005 | Pentax Optio 50 Digital Camera
Pentax Optio 50 Digital Camera Logo
277 people viewed this question
Top Pentax Cameras Experts
Ekse
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
