You can find owner's manual for Kenmore Oasis washer at http://www.managemyhome.com by searching for your model number. From the Kenmore owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
"Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it."
I have a dryer that all of a sudden isn't heating, the controls work as normal, light on, basket...
(More)
I have a dryer that all of a sudden isn't heating, the controls work as normal, light on, basket tumbles but I'm not getting heat to dry. The dryer has been working well, it's about 4 years old. I'm looking at heater element, thermistor, thermal cut-off and thermal fuse to solve. Any help is appreciated. Thanks, John Maryland
my washer is making a terrible grinding sound during the spin cycle, it sounds like a car stuck in...
(More)
my washer is making a terrible grinding sound during the spin cycle, it sounds like a car stuck in gear. it is also leaking water onto the floor
we installed new samsung front load washer & dryer yesterday. We used a level after...
(More)
we installed new samsung front load washer & dryer yesterday. We used a level after installation that said both were perfectly level, but the washer violently shakes and moves when it does the spin cycle. Any suggestions?
