Question about Sony Handycam DCR-DVD300 DVD Camcorder
Battery not charging
We have had the camcorder since 2003. Lately the battery would not hold a charge. We bought a new battery and tried to charge it, but the charging light does not stay on. (The battery is in the camcorder when charging..not in a self contained charger). The camcorder will work if just using DC.
5 Suggested Answers
  • 473 Answers
SOURCE: Can a lithium ion battery be overcharged?
Here's a small FAQ I found: 1) My lithium ion battery is the SONY NP-FP70 Battery Pack. Does the fact that the battery is called a battery pack mean that it has built in circuitry to prevent an overcharge? No. I write with some authority since I've dissected too many and there is no such circuit in the battery. From a system perspective it doesn't belong there. 2) Is there any way of knowing if my SONY BC-TRP charger has the circuitry for preventing an overcharge? You'll have to ask, but the key clues are: a. The documention tells you to not leave it plugged in overnight. b. The battery gets too hot and melts the plastic. 3) If I charge my battery in my camcorder (SONY DCR-HC40), can I assume it has the built in circuitry to prevent an overcharge? a. One can't assume anything. b. But from what I read on that model, you plug it in and forget about it. To do that, it would have a proper charge circuit.
Posted on Sep 13, 2005
  • 80 Answers
SOURCE: Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (
Posted on Feb 15, 2007
SOURCE: how to charge a EFORCE FH50 Compatible Battery
Its pretty simple; Probably u will be having ur sony handcam charger having a cable thats supposed to fit into ur camcorder and then charge the battery. For charging the EFORCE FH50 battery, you just need to insert that the of the same cable directly into the battery(DC-IN slot) and plug ur charger into the wall socket. It normally takes 135 mins to completely charge the battery. Once charged the LED at tthe DC-IN slot will turn off. (During charging its yellow)
Posted on Apr 06, 2009
  • 149 Answers
SOURCE: lost the charger of my sony dvd201 cam corder. is
Hello. Yes, you do need power to open the disc door. When you slide the disc cover open switch, you should hear the little musical sound, and then the "preparing to open cover" appears in the lcd display. Then the door opens automatically. As for charging the corder, you can get a new ac charger for 25 bucks on Ebay. Sony uses a special plug that is inserted. If you want to go the cheaper route, I saw mobile *battery* chargers for your unit(not to be used as camcorder power supplies) as inexpensive as 8 bucks...most were 10 dollars and up...the input voltage/current to the cam is 12v @ 500ma. However, the fact that the connector isn't the generic "cylinder" shaped power connector makes purchasing a compatable power source a necessity. ---Rick
Posted on Sep 16, 2009
Testimonial: "thanks very much mastertech48 ur pesponse was very helpful"
0 characters
1 Points
Hi i have a sony dcr-pc3 my wife bought it in 2000 and it never holds a charge the longest we get is about 10 minutes we bought a new battery and have just bought a new charger same old...
Well if you have bought the right battery and the proper charger this sounds very odd, did the amp hr and every say the same details on the battery & charger as the old one? when you charge the camera how long was it till you used the camera? as Sony cameras lose around 30% charge per week, I know because I have a Sony still camera and movie, both lose charge, my still camera goes flat in 3 weeks after a full charge with no use at all, so they are never good bits of equipment with batterys.
Jun 20, 2010 | Sony Handycam DCR-PC3 Mini DV Digital...
Camcorder wont charge
Try cleaning the brass tabs on the battery and the point of contact brass in the camcorder. Use a soft brass brush (gun clean kits at Wal-mart carry them in all sizes). I do NOT recommend useing steel wool because steel wool will leave little bits of itself behind and cause shorting out
Sep 24, 2009 | Video Cameras
Panasonic ds27 camcorder charge
It could need a new battery.  The battery can't hold a charge in it anymore.
Sep 18, 2008 | Panasonic NV-DS27B Mini DV Digital...
Nickel metal hydride battery wont charge
It is time to replace the battery. What is the model number of your camcorder.
Feb 28, 2008 | Video Cameras
Won't hold a charge
It's the battery, over time the amount of power that the battery can store diminishes, and the indicator will still show a full charge, even though it is not fully charged. try getting a new one, from sony, or a 3rd party supplier. ;)
Jan 17, 2008 | Sony Handycam CCD-TRV37 Camcorder
Power problem
Your battery is probabily uncharged or disconnected. Try taking the battery out and putting it back in. Then charge it (by plugging in the AC adapter) until the green activity light stops flashing. If this does not work, your battery is probabily dead. Did you short it out? Or perhaps it is old. Li-Ion batteries (the kind used in these machines) lose their ability to hold their charge in a few years - even if they're not in use! So, if your battery is 3 or more years old, try considering a new battery.
Jan 03, 2008 | JVC GZ-MG130U Camcorder
Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Apr 13, 2006 | Samsung VP-W75 Camcorder
Sony DCR-HC40 Battery Charging Problem Hi Mates - I did purchase a Sony DCR-HC40 camcorder around an year back and it was working superb till few days back. As of date, i am facing a problem where...
Had the same thing happen to me. Went out and bought a new battery and it, too, does not charge. Apparently something messed up with the in-camera charging system. It will charge for several minutes (charge light illuminated) and then the charge light goes dark. Battery gage shows that there is virtually no time left on either battery (old or new). Anyone have any ideas other than a trip back to Sony?
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Can't charge the battery
# New batteries need to be drained by using the camcorder until the viewfinder indicates the battery is empty. Follow these steps: Once the battery has been drained, you may use the charger to recharge the battery. # Consult your manual for the amount of time the battery requires on the charger to get a full charge. # A full charge will be delivered by the charger. # Some camcorders have a Refresh feature, which will automatically drain the initial charge on the battery. This allows the battery to fully recharge.
Sep 06, 2005 | RCA CC-432 Camcorder
Sony Handycam DCR-DVD300 DVD Camcorder Logo
22 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
