Question about Dryers
My dryers not working
Ok i just got my dryer used and i hooked it up 2 days later cuz we needed to get a 4 prong plugin ok i hooked it all up and it put sum damp clothes in and pressed start it worked. i came back about 20 minutes later and it stopped. i have turned the timer to restart it and nothin happened. i have changed it to different settings and nothin happened. the light inside the dryer is on and there is power comming from the wall plugin. but it just wont start i have tried everything that i can think of to get it to work. if u could help me with this matter i would appreciate it alot thanks
  • ezgmom Nov 07, 2008
    It was the door switch. I didn't even know that existed. Mine was stuck in the "in" position. I pulled it out, shut the door, and the dryer started right up!
    New Friend:
    Problem Solver:
I have a LG DLE2516 and something keeps tripping the breaker. It doesn't seem to happen when I run the air only (no heat) or low heat. Please help!
Posted on Dec 07, 2009
  • 447 Answers
If one of the lines is lost (230v circuits have to hot lines) the light only works on 1 line check your connections. There is also a thermal fuse that shuts the machine down when its overheating. If there is 230v at terminal block. The fuse is what i check next, well doorswitch too make sure the switch isnt broken (upper right of door). PLEASE RATE MY HELP
Posted on Oct 03, 2007
SOURCE:
How do I hook up a 4 prong cord to dryer. black, red, green and white wires?
Watch the video below for full description and be SURE to use and tighten the clamp that secures the chord where it penetrates the rear of the dryer. Do not leave chord loose in the hole as this COULD cause dangerous problems later on.
4 prongs cord Whirlpool 29 inch electric dryer
Nov 21, 2015 | Dryers
Maytag Neptune dryer went from 4 prong to 3 prong...cabinet light works but dryer we won't star
It's not wired right. You're only getting 110 vac to the machine which is why you are seeing some lights but no operation. Make sure when you went to the three prong plug you connected to both 110 vac lugs and common.
Feb 17, 2014 | Dryers
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
No heat-switched from 4 prong to 3 prong-Ground????
There should be a ground bonding ******** the Neutral (White) wire at the terminal block for 3-prong configuration. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the information, thoroughly. Instructions on how to convert from 4 to 3 prong are mentioned in the "Additional Notes" section. If you have questions, or require addtional assistance please let me know. I hope this helps you.
Jan 13, 2009 | Kenmore 67032 Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Dryers Logo
620 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
