Brother printer/fax/copier i have changed the inks in my printer done everythink that the manuel says but it keeps telling me that the black ink is low it really is frustrating me
  • 64 Answers
Ok here goes . . . if the machine you are talking aboput does not have a screen ie. that you can browse menus on then you need to switch it off open the door/flap and switch it on holding down reset/demo button when all for lights become lit release the button and close the door/flap
if you are using a screened model then within the menus you should be able to get to "life counters" narmaly within the "printer optins/properties" menu and should be able to reset it from there.
this error occurs as brother machines do not know how much toners is in the cartride. instead they use a page count system eg. every xxxx pages you do it will say toner out
Hope this helps
Pete
COPS
Pete@wedotoners.com
Posted on Nov 29, 2007
  • Pete e
    Pete e Nov 29, 2007
    ok here goes . . . if the machine you are talking aboput does not have
    door/flap
    Hope this helps
    Pete
    COPS
    Pete@wedotoners.com
    Problem Solver:
  • 17 Answers
Nutty... are you using original brother OEM cartridges, or after-market rebuilt or equivilants? If you're not using original stuff, I highly reccomend that you do.
Posted on Oct 12, 2007
  • James Mastrine
    James Mastrine Oct 12, 2007
    PS: It might also help if you mentioned what model brother we're talking about....
I have a brother fax machine model 2480c, just want to know for the ink catridge, do i need full ink in the entire 4 catridge in order for the printer to work OR i can just have say the black colour...
1) The Brother printer is structured in such a way that it will stop all the printing operations if any one of the ink cartridges are empty.
2) If the printer continues printing inspite of having anyone empty cartridge then the cleaning cycles would suck air from the empty cartridge.
3) This would damage the print head.
However, the black and white print mode can operate exceptionally well when the cartridges are empty.
Nov 12, 2010 | Brother Office Equipment & Supplies
My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Sep 10, 2009 | Brother MFC-290C Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Cant remeber the ink cartrige #
Hello, there are two ink cartridges for this printer, 336 Black & 337 Color,the cheapest way to buy these is at costo,Please do not refill your old ink cartridges as the printer will on most ocassions tell you to remove the faulty cartridge, however you may get away with a refill only once. I changed to a Brother MFC it was easier to install,prints faster,it has fax,scan,copy phto capture, you will need to buy use printer lead for this machine as it does not come supplied, the bonus of having the Brother MFC 235C is that the 4 ink cartridges are half the price of one HP Black Cartridge,check out www.999inks.co.uk
Jul 12, 2008 | HP Photosmart 4180 All-in-One Printer
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
INK
Brother multifunction printers require that all ink be filled before you can print to it. If any ink is empty, you cannot print, even if you are printing only black.
Jun 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
64 people viewed this question
k24674
Marvin
Marvin
