Receivers
Problem for Receivers
Generic problem for all Receivers
Denon AVR 5803
By tobyg on Oct 02, 2007
The subwoofer port on the back of my receiver doesn't seem to be working. I know the sub works. I don't think I accidentally disabled it. If I did, I don't know where to re-enable it.
Same Problem
Mar 06, 2008
-   My brother was over the other night and switched the function knob- result- sub went out. Hav'nt been able to get back functioning since. Tried the size speaker settings, SW on/ off control, everything else i can think of...nothing. The Sub is on and O.K. Can't figure it out. Couyld use some suggestions as well!
-   mjcvelbar
Jan 02, 2008
-   same prob with denon avr1907. Went through settings with denon support over the phone, but no solution. Sub itself woking fine,cable brand new and not shorting. Hard to belive somthing wrong internally. 4 month old factory refurb. Frustrating.
Small speaker/large speaker idea makes sence. wish that solved it but no. Any other ideas on what to look for?-   DRIVERDOG3
Jan 02, 2008
-   sa-he75 no subwoofer output.speaker size small .subwoofer level at 10.sw is functioning on another speaker output.all else fine. proper cable in use for sw.all speakers pass test.any clue ?-   vitalcam
Best Solution
posted on Oct 03, 2007
Very Helpful)
dukic
Rank: Wiz
Rating: 82%, 144 votes
If there is "large/small speaker" settings on your receiver, maybe you set speakers on Large. Some receivers, when set speakers to "large", won't redirect signal on subwoofer.
Was this helpful?
Yes
No
Solution #2
posted on Apr 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have similar problems with my sub connection on my 2805. My sub activates now and then when very low frequencies are being played, but only when the volume is about -35db or louder. The surround EQ might have been changed on your receiver. I have a feeling that the 2805 has a weak connection to the sub out jack so another possibility is that you have a shorted-out wire. Couple of suggestions: check to make sure "cinema EQ" is not on, as it compresses the frequencies to the upper and lower dynamic ranges, which might mean LFEs are not being played. Also check your crossover frequency and set it to somewhere higher (200Hz is a relatively high crossover frequency that would be good with very small main speakers, while 80 hz is a low crossover point that would just add a little extra oomph to gigantic speakers capable of playing very low bass).
Popular Solutions for Receivers
Questions and Unsolved Problems for Receivers
Answer
dvd draw opens when swithed if i insert a disc it does not read it and the draw opens again
Answer
can't get the optical inputs to trun on, I don't have the remote
Answer
after its on awhile it cuts out i guess it gets too hot
Answer
unit turns on for about 3 seconds and turns itself off...I tried unplugging unit for a couple of... (More)
Answer
I have onlyo TX-SR702, it does not have audio output even monitor out for setup menu but remote and... (More)
Describe your Receivers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Receiver Experts
Top Audio & Video Equipment Repairmen
in Sedona, AZ
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
