Question about GE Advantium 120 Convection/Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
While microwaving food unit shuts down. No clock display or anything and at this point none of the buttons work. Within approximately 15 minutes or less the display panel lights back up and the unit requests the time as if it had just been energized for he first time. Circuit breakers are fine, no trips. This unit though older was never previously installed. Used as display model. Just hooked up within the past month. This problem occurred almost from the beginning.
  • 1 more comment
  • dsrios Oct 07, 2007
    there doesn't seem to be any rhyme or reason as to when the advantium fails.
    No scrambling of the display that I've seen. It just goes dark as if a fuse had been blown.
    This model is a scb2000cww 03 and it is an advantium 240 not a 120!
  • dsrios Dec 03, 2007
    I'm not sure where the negative rating came from. I haven't even had a chance to get someone out here to check it out yet.It's not the highest priority at the moment.
  • itsmedebby Dec 27, 2007
    I have a GE Advantium 120 oven that was never removed from box before storing in empty house for about one year. It was installed and worked and then I moved 4 months later and re-installed. The first time used microwave everything shut down. Power is getting to the plug but the unit simply went dead. No lights - nothing. Any suggestions?
  • GE Master
  • 9,098 Answers
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Posted on Oct 05, 2007
  • William Miller
    William Miller Oct 07, 2007
    Okay, good. Thanks. That model uses a thermostat, which is self-resetting.
    The fact that it fails and then just comes back on its own seems to point to the magnetron thermostat tripping. That would happen because the magnetron is overheating.
    Here's a test to try: Run the microwave on full power with a cup of water in it and see how long before it fails.
    When it cools down and comes back on, run it at 10% power and see if it runs for a much longer time.
    Chances are it will, and that means you probably have a bad magnetron.
    That model should have a 5-year waarnty on the magnetron, so if it's not that old, you would only have to pay for labor.
    You can save about $50 on labor if you remove it from the wall yourself and take it in for repair.
    Removing it from the wall is a two-person job (for safety's sake) and it helps to have the installation instructions.
    You can download those here:http://tinyurl.com/2ezkqh
    You can contact GE Customer Relations at 1-800-386-1215 and tell them your problem and they will put you in touch with a local authorized warranty servicer.
    If it's out of warranty, and you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa:http://tinyurl.com/yzjozk
    You can find helpful exploded view diagrams and order parts by entering your model number here:http://tinyurl.com/gv383
    Good luck and be safe.
    I appreciate your thoughtful rating of my reply.
  • William Miller
    William Miller Dec 02, 2007
    Such an extensive reply rated as inappropriate? Ouch...
I have the Advantium 240 and it lets me select the cooking selection but when I push the round center button to start nothing happens. Also the interior light stays on
Posted on Jul 04, 2010
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
How do I replace parts on the door of the GE Profile Advantium 120 Microwave
the door will come apart so you can screw it in from the inside its pretty easy just lay it out so you dont lose parts same with the clips they shoud either snap in when you have door apart or screw it in its just time consuming and terious work buy its do able
May 01, 2012 | GE Profile Advantium 120 Wall Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
The display on my GE Advantium microwave oven shows "LOCKED". I tried holding the clear/off button but it won't clear. the microwave is unusable at this point
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If yours is an Advantium, one of these owner's manuals will help you set the clock if you need help:
http://www.microwavedisplay.com/sca1001kss_om.pdf
http://www.microwavedisplay.com/sca2000_sca2001_om.pdf
If you still need help, note that FixYa's Web site is currently not notifying us Experts when replies to our Clarification Requests are posted, so please post a new help request, but be sure to include your full model number from the tag in or on the unit.
Apr 24, 2010 | GE Advantium 120 Convection/Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
GE Advantium 120 Convection/Microwave Oven Logo
1,123 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
