Question about Sharp 20F640 20" TV
Beeping noise and no power
I have a Sharp TV and I turned it off and noticed a beeping noise somthing simular to a cricket. When I went to turn it back on it didn't work. The power light didn't come on or anything.
    Scholar:
  • 57 Answers
The "cricket" sound you heard can mean any number of things:
1. A component in the power supply that sets the frequency failed, causing a high frequency (hence over-voltage) in the SMPS, which then also failed. The initial failure may have occurred in a small high-voltage capacitor in the power supply (around 160V or so rated)
2. A failed horizontal drive or vertical stage, which drew so much current that the switching semiconductor in the SMPS failed.
Note that such failures often occur like dominoes (one, then two, then three, and so on). Sometimes the fuse itself will not even blow out. The best thing to do is to first remove the line-output transistor and then replace the switching semiconductor(s), nearby zeners, capacitors, and fuse if blown. Then turn the unit on and check for about 105V on the collector terminal of the line transistor. If that's fine then turn unit off, replace the line transistor.
Of course the above procedure is only a guide; the precise steps taken will depend on your exact make and model. Also, if the above sounds mind boggling then rather take it down to your nearest repair shop. Good luck.
Posted on Jan 18, 2008
SOURCE:
Television won't turn on.
Hello
The same problem i am also facing bin last weak what i will suggest you that neverturn off ur TV by remote switch off directly from the scree from next time it will be helpful for you from next time...
Thanks & Regards
May 24, 2009 | Televison & Video
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My tv won't turn on...
The sound you can hear is the power supply starting then finding a fault and shutting down this cycling trip indicates a fault condition which need a technician to solve.
SUPER8
Dec 29, 2008 | Panasonic CT-36HL43 36" TV
Tv troubleshooting
There is problem in the power Supply section.check the h-out Transistor if Damage then Change for the Same COde #
Nov 13, 2008 | Televison & Video
Tv turned off and started beeping noise
Sound like high voltage splitter ( born or defected ) Am sure this is your problem. Or maybe fly back defected. Check for possible loose connections. Thank you !!
Jul 20, 2008 | RCA P52926 52" Rear Projection Television
No pic, beeping noise
It seems to be an issue with the power board. The relay may need to be replaced. I would recommend getting it serviced by a professional TV repairman, than try a DIY..
Jun 29, 2008 | Televison & Video
Tv went out, made a pop sound and won't turn back on
Sounds like the flyback went out. Your set is a CTC195 you can get a replacement flyback for it at the following link. They also provide free instalation instructions and free on line tech support.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | RCA P56950 56" Rear Projection Television
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
Sharp 20F640 20" TV Logo
210 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
